Originally Posted by
tigger73
Stock Tig intercooler is 32mm so S3 is 21% increase just in thickness. I'm not sure about how "dense" the S3 one is compared to stock Tig one but just with the thicker core it should be a reasonable improvement.
I figure if the S3 intercooler is good for power outputs around 200kW that should do me just fine
All mounting points are identical, so this is a bolt in bolt out job.
And carefully removing the aluminium end with a hacksaw and screwdriver making sure not to nick the hose.
Blimey! 32mm is the same as my 1.8tsi. I would have thought the Tiguan would have at least the Mk6 GTI 38mm IC.
I have the same S3 IC sitting at home waiting for me to replace the 32mm I have.
You should have removed the green O-ring & kept it as a spare as it is used in the pipework between the turbo & the IC
