Page 63 of 101 FirstFirst ... 1353616263646573 ... LastLast
Results 621 to 630 of 1001
Thread: Tigger73's 125TSI Tiguan Build Thread
  1. #621
    Quote Originally Posted by Wynnston View Post
    Eh, I seem to be the only Tig in WA that goes to the WA outings, everyone seems to be welcoming, I'm sure you'll get a similar reception.
    Some don't even know that the Tig shares a lot of hardware with their Golfs and are quite surprised when you tell them.
    Well turned out I was the only one flying the Tig flag.... but chatted to quite a few closet Tig owners
    I posted a few photos from the day here: Day of the Volkswagen, Adelaide, Sunday 16/03/2014.
    Was so busy taking photos of everyone elses cars I forgot to get a good shot of my own car
    A box arrived the other day while I was away
    Jun 2009
    Keen to see what was in the box!
  4. #624
    Quote Originally Posted by team_v View Post
    So am I! It's currently sitting out in the warehouse at work... May have to visit the office on the weekend to collect it.
    Jun 2013
    I think I know what it is Haldex ? or may be intercooler !
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
  6. #626
    Well couldn't resist so took a quick trip into the office before lunch. This afternoon fitted up the new S3 intercooler....
    Some minor challenges so I used the "phone a friend" lifeline. Turns out Ramee and I took slightly different approaches to removing the headlights and front bar plus hoses are different between 1st gen and second gen Tigs....
    Managed to get 90% done in the afternoon and final bit of reassembly after tea. Off to do a test drive...
    Jun 2013
    Happy to hear everything went well congrats! May be you can do a detail DIY for rest of us Tig owners..
  8. #628
    Quote Originally Posted by Ramee View Post
    Unfortunately I didn't take many photos along the way as I was on a tight timeline (trying to get it finished in the afternoon).
    However I did manage to take a photo comparing the two cores:
    Top is the stock Tiguan intercooler (Part #: 3C0 145 805 R) and the bottom is the Audi S3 intercooler (Part #: 1K0 145 803 BE). This one has the plastic end tanks and is the newer style. Possibly the older S3 intercooler with metal end tanks is slightly better performance but this one was available at the right price.
    DIY process is quite simple.
    Remove everything in front of the intercooler/ A/C condenser:
    Unbolt the condenser/intercooler/radiator, slide out the old intercooler and slide in the new one.
    Put it all back together.
    I managed to take off the front in two large pieces:
    • the front spoiler/grille
    • headlights/front bar
    To do this I did have to unbolt the bonnet latch and remove the bonnet release cable so that I could remove the headlights/front bar as a complete unit.
    Also the intercooler hoses/connectors were different between the "old" Tiguan intercooler and new S3 one. I had to do some minor surgery to the stock hoses to remove the metal connectors at the intercooler end so that they would slip over the connection (rather than fit inside the housing and be secured with clips).
    It all ended up working out OK. I was a little concered that after I butchered the stock hoses that they wouldn't fit and I'd be left without any hoses and unable to fit my old intercooler back in. The S3 hoses are too short and are also the wrong shape on the turbo side to fit into the Tig, so you need to use your stock hoses.
    Erskineville, NSW
    What is the thickness of the OEM intercooler?
    S3 core with plastic tanks is 38.7mm - just trying to work out how much the Tig was hobbled ex-factory
    You realise the plastic tank unit has these features over the S3 metal tank unit:
    4 more bars spaced more closely together
    * More equivalent frontal surface area, as well as internal cross sectional area - improved flow capacity
    The plate design inside the bars are more closely packed
    * Improved efficiency due to greater rate of heat transfer
    Smoother flowing end tank ports
    * Improved flow characteristics compared to the S3 fittings which have steps in diameter causing turbulence.
  10. #630
    Tigger73's Build Thread
    Stock Tig intercooler is 32mm so S3 is 21% increase just in thickness. I'm not sure about how "dense" the S3 one is compared to stock Tig one but just with the thicker core it should be a reasonable improvement.
    I figure if the S3 intercooler is good for power outputs around 200kW that should do me just fine
    All mounting points are identical, so this is a bolt in bolt out job.
    Here's the stock connection:
    And carefully removing the aluminium end with a hacksaw and screwdriver making sure not to nick the hose.
