Damn it does hook up and get going. RIP fwd lol
Sent from my HTC One X using Tapatalk
I'll likely get one with a cable switch but will probably leave the switch in the boot and not run it all the way to the cabin. I really don't want to be drilling any holes to mount it in the cabin.
If I could use some of the blank buttons next to traction control etc then I would seriously consider spending the time/effort to do this and make it look like an OEM install. Though with a push button it would only be selecting stock/race settings and not the one in between.
If it's anything like the sprint booster you'll play around with the settings to begin with to find the one you like and then just leave it there. Suspect it's going to live 99% of the time in "race" mode and may get changed back to "standard" for country trips. But even then I don't think it engages the rears when you're cruising on the freeway/straight country road so there's probably no benefit in changing out of "race" setting anyway... But I like to have the option
www.TheRapidWrench.Melbourne
The convenient, professional and affordable mobile bicycle mechanic that comes to you!
My RS build thread
Yes FWD is dust. And in the wet even dustier.... if that's possible
tigger73, your two points as to why the sprint booster is a worthwhile mod both relate to how it affects some characteristics of the DSG transmission. I can't help but think that due to the 'shortness' of 1st in the MT (& 2nd to some degree), the sprint booster would make city traffic a bit of a pain for manual drivers...
Might have to wait for someone with a manual to chime in... Lucas, what's first gear like in your R??
I'm kinda tempted, but leaning toward putting the money toward Stg II...
It is a different unit between the auto/DSG and manual. Slightly different part# so obviously they are a different box (programming most likely).
If I had a choice between stage 2 and a sprint booster I'd do stage 2 for sure.
The sprint booster is great but it's like some of these 1%er things that make it nicer but if you had to you could live without it (though going back to stock now is a real drag).
Not sure if there are any other manual Tigs out there with one. I know Lucas has one in his manual Golf R and says it's an improvement.
Haldex Controller has been ordered.... I decided to get the non-switch Race mode only controller after I confirmed that the rears are not engaged in Race mode when driving on the highway. This would have been the only reason to get the switchable version IMHO. Why pay extra for a feature you're never going to use?
Sweet !! That is what I thought. But like you said it nice to have that three button switch. And much nice to have some how if we can build a system that change Haldex , Suspension, Exhaust sound all in one button press![]()
2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
Yes I've toyed with buying a "sport" button, getting a bi-modal exhaust, active suspension and perhaps hooking up the Haldex and Sprint Booster as well but then I figure if I really wanted a sports car I probably should have just bought one instead of trying to build one out of an SUV.
However I would consider getting one of those soundaktor units hooked up to a sport button and reprogram it to pipe in an R32 engine/exhaust note. That would be pretty cool
A couple of things I've been toying with recently... not sure whether either will eventuate
An R-line front grille for the 2008-2011 model:
I've priced these up but it's about $1200. VW has them in stock locally. I'd be tempted to do it for $300-$400 but $1200 is seriously a lot of $ for a few bits of brushed chrome trims.
The other thing is some aftermarket headlights with new style DRLs:
I've been told these guys will manufacture these lights in RHD![]()
Hey mate, TIG is looking really good. Saw you the other day at Conyngham St. I was driving the black Caprice with few antennas on the back window.
