Page 52 of 101 FirstFirst ... 242505152535462 ... LastLast
Results 511 to 520 of 1001
Thread: Tigger73's 125TSI Tiguan Build Thread
  1. #511
    Nov 2007
    You could be right. I know APR is "nominally" 189kW with stage 1 so should be a few more with the DP. Still looking to get some good data on this. Unfortunately I didn't get a "stock" dyno done so I don't have a good benchmark
    I have been talking to Guy at APR and he reckons the DQ500 has larger driveline losses than both DQ200 and DQ250 so it will take out more than you Golf boys normally lose. Plus the AWD system on top so looks like I might need to put on a K04 to make up for it...
    Although I'd love to it's a fair few $ and I really ought to be spending this on other projects around the house (or so my wife says).
    Guy has said that there is about 8% additional drivetrain loss in DQ500 compared to a manual. What sort of intake are you running?
    I had a Carbonio and don't remember a massive drop off at 6000rmin so a decent CAI may be the way to go. For what its worth my Stg 2 made 160kw atw in a manual .....
  2. #512
    Arrawarra
    ..... For what its worth my Stg 2 made 160kw atw in a manual .....
    Just when i decided stage II hardly seemed worthwhile over stage I, someone comes out with this... Looks like i'm interested again now!
  3. #513
    ^ thats a good point - what are your mods now Tigger?
    VAR intake (got a pic so i can see how it looks on the Tig? Im running a hybrid intake using the VAR carbon airbox.)
    VAR downpipe
    APR stage 2 tune
    If your intake includes a new pipe that goes past the battery, behind the engine and down to the turbo - can you show with a picture or explain what has happened with the MAF sensor (which is along side the battery on the TSI engines). Does the VAR intake use the stock plastic MAF housing or does it have a dedicated area on the pipework for the MAF sensor to be screwed in?
    If so, then have you checked fuel trims? You might want a honeycomb MAF screen to straighten the airflow over the MAF too.
  4. #514
    Nov 2007
    Quote Originally Posted by MGV View Post
    LOL, its a matter of diminishing returns though mate, Stg 1 in a manual makes ~150kw atw, so an extra ~10kw and ~20NM is what you get for the intake and exhaust ...... for me every kw always counts so worth it IMO ....
    PS .... this thread and Guy's Stg3 build has now made me consider another Tiguan as a run-around to replace the Mk4
  5. #515
    When comparing stage 1 to stage 2 results, even though stage 2 doesn't have a huge peak difference over stage 1, the torque curve holds flatter for longer (where as stage 1 torque builds, peaks and then drops off rapidly) with the free flowing down pipe making for a faster car overall and a smoother/more consistent power delivery.
  6. #516
    Nov 2007
    +1 ^what Lucas said
  7. #517
    Erskineville, NSW
    re: drivetrain losses. My Legacy used to lose 30% through the Auto/AWD combo. Heartbreaking it was.
  8. #518
    Tigger73's Build Thread
    Well at least I'm lucky enough not to have a 6 speed auto - although pretty indestructible they are a lot slower.
    Lucas I'm currently running a stock intake which I have done for all 3 dynos. The only hardware change is that I fitted a resonator in the exhaust for the last 2 runs. So hardware wise the APR vs Viezu were identical.
    ...and speaking to Guy he also mentioned yours was a particularly strong car - outputs above average.
    I do have a CAI but not on at the moment - I was running my stock intake when I had it dyno'd first and kept things the same for the following dynos. Will be putting it back on hopefully this weekend. I did have your old Carbonio but it ended up on Tiggy1's car
    That's funny - I think it was a bunch of your posts that got me inspired originally
    VAR downpipe
    APR stage 2 tune
    VAR intake is going back on shortly. It uses standard MAF sensor and everything bolts on (hose clamps) before the MAF - just connects up pretty much in the same place as the stock intake and pipework goes off in around the same direction (will check/take some photos when I change intakes).
    I did see your honeycomb flow straightener. The flow comes from very close to the same location as stock pipework so I'm pretty certain that the readings would be similar.
