Page 51 of 101 FirstFirst ... 41495051525361 ... LastLast
Results 501 to 510 of 1001
Thread: Tigger73's 125TSI Tiguan Build Thread
  1. #501
    Adelaide hills, SA
    Quote Originally Posted by Tiggy1 View Post
    Great to hear you've finally got a result
    Possibly not as much straight out power as expected, but certainly looks to be a more useable tune for around town - certainly backs up what others say about APR tune being the "go to" one for our Tigs (at the moment anyway), although I'm sure Viezu will keep working on theirs to get it to where it needs to be....
    Hmm, not for those who don't want to get their ECU opened. I can do the TSI Tiguans over the port now, with Autologic. They should be as smooth as silk and very linear too. I enjoy mine in T5 every day. The disadvantage of the Autologic is they have only stage 1, but on average you get +30kW increase and +70-90Nm torque. And there should be no mishaps, the Autologic is the safest way to remap your engine ECU.
  2. #502
    Well as the old saying goes if you can't beat them, then join them.
    I'm still not 100% on the power output. I think there may be a couple of factors at play here.
    First I suspect there is quite significant driveline loss in the DQ500 / AWD system. I'm hoping some other people may be able to quantify this by dyno testing of a stock DQ500 Tig.
    The other factor is like you Tiggy1 I have slightly oversize tyres (my speedo now reads true). I know this will make a slight difference and if it is 5% I'm chasing then this may well be the 5% variance right here.
    I do have my old wheels still in the shed and if I was super keen I'd put these on and run it on the dyno again but I know talking to the dyno guys it will change the result.
    So I'm thinking case closed even though there's still some unanswered questions. The proof of the pudding is in the driving and I'm very happy with how my car drives with the stage 2+ APR tune.
    Now to bolt my other bits of hardware (back) on and enjoy driving my car at last!
    Sep 2011
    Townsville, Nth Qld
    Yep, and at the end of the day that's what it's all about - enjoying the drive
    On another note (and apologies if it's covered elsewhere), Autologic have obviously cracked the ECU security to tune through the OBD Transporter? Or, have they found another way around it?
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
  4. #504
    Adelaide hills, SA
    All goes over the OBD2. Yes, they don't just hack for the tuning, the Autologic's team of VAG software engineers can also repair other software in many control modules and much more.
    Sent from my GT-N8000
  5. #505
    All goes over the OBD2. Yes, they don't just hack for the tuning, the Autologic's team of VAG software engineers can repair other software in many control modules and much more.
    Transporter checked my car last week and it is now readable over the port. Every other time it hasn't allowed it so my ECU should now be port tunable.... Just needed to wait
    Adelaide hills, SA
    Yes, at least with Autologic.
    Was your APR tune done over the OBD2 port?
    Many late models cars that I have serviced lately are OBD2 tuneable with Autologic, so I would say that they must have been busy developing the tunes for the late models.
  7. #507
    I believe it was readable but they still couldn't write... So halfway there.
    So yes I think people have been busy cracking these RCUs so they don't need to be bench tuned. Would have made my life so much easier if that was the case.
    Just posted up some K04 Tiguan Data above:
    http://www.vwwatercooled.com.au/foru...lts-92358.html
    From our in house dyno readings on DQ500 equipped cars (Tiguan & TTRS'), they pull out ~ another 6 - 8% over the manual variants when run in 4th or 5th gear.
    Very happy with Damian's run - this was a production file, off the shelf - same as every other APR Tiguan around the country is running. One flash & done.
  9. #509
    I'd say your on about 185-190kw at the engine/flywheel which is about all you will get out of the K03. I'd be more inclined to say a 20-25% drive train loss through the gearbox and AWD system.
    On another note I suspect (and am still to have this confirmed) that there may be quite substantial drive-line losses in the DQ500 gearbox. If everything is working as it should on my car, the engine "should" be putting out close to 200kW. Assuming 30% driveline losses would give 140kwaw.
  10. #510
    You could be right. I know APR is "nominally" 189kW with stage 1 so should be a few more with the DP. Still looking to get some good data on this. Unfortunately I didn't get a "stock" dyno done so I don't have a good benchmark
    I have been talking to Guy at APR and he reckons the DQ500 has larger driveline losses than both DQ200 and DQ250 so it will take out more than you Golf boys normally lose. Plus the AWD system on top so looks like I might need to put on a K04 to make up for it...
    Although I'd love to it's a fair few $ and I really ought to be spending this on other projects around the house (or so my wife says).
