Page 38 of 101 FirstFirst ... 2836373839404888 ... LastLast
Results 371 to 380 of 1001
Thread: Tigger73's 125TSI Tiguan Build Thread
  1. #371
    London
    I'm sure I've seen vinyl wrap cut outs for various parts of the Tig interior on ebay from a Chinese seller. Would save you having to make your own cut out.
    I have checked ETKA and there is no alternative glovebox latch for the Tig that I could see. It's a shame really as the Golf version did look good although not real brushed aluminium - just coated ABS.
    2011 Candy White Tiguan R Line 170 TDI DSG | Pan roof | Park assist & RVC | RNS 510 | MDI | LED's | 20" RS5 Wheels| Bi-xenons & AFS | Front & Rear footwell lights | Door warning & puddle lights | Mirror puddle lights | LED Tail lamps | Eibach Pro-Kit Springs
  2. #372
    New mod coming for the Tig - should be arriving this week. Hopefully this one fits!!!!
    Tigger73's 125TSI Tiguan Build Thread-444356_x800-jpg
    It's a Hella smoked 3rd brake light - should be straight plug and play for the OEM part (I think the OEM part is also made by Hella).
    If these work I'd consider organising a group buy for these as they also fit MkV Golf/Jetta.
    Also anyone wanting a set of R8 coil packs please let me know as I have some landing early next week: R8 Coil Pack group buy from ECS
    Oct 2010
    It will fit, I have it on mine.
  4. #374
    Quote Originally Posted by Suffolk View Post
    Beat me to it!!!
    Did you use any special tools to do the swap?
    Oct 2010
    This was one of my first mods in 2010. No special tools needed. There is double sided tape around the trim, and 4 clips on the bottom, so be gentle. Best way to take it off is from the top first so the clips have more room to move. If you do use any tools, make sure they are plastic. I think I used a plastic ruler. I like it but the original red looks better on a black car, you will agree once you change it.
  6. #376
    Oct 2010
    Next mod, hella brake lights? Or p3 digital gauge, led headlights?
  7. #377
    I've looked at the Hella brake lights - though I'm not convinced with reversing the colours and having the silver around the outside - especially on a black car.
    Tigger73's 125TSI Tiguan Build Thread-69914_x800-jpg
    These are the other tail lights that I would consider but they are only available in LHD...
    Tigger73's 125TSI Tiguan Build Thread-82905-jpg
    No need for a P3 gauge as I have an AutoPolar which does pretty much everything the P3 does and more (mirror dipping ).
    Also looked at LED headlights but I've resisted the urge. Until I find something that is an improvement on the OEM part I'm not that interested. And realistically I wouldn't pay more than around $500 for a set, it would have to be RHD and not bi-xenon as I'm not going to put washers and levellers in. So basically I'm buggered!!!!
    I've been looking for some options for upper/lower front grilles but nothing really jumps out. I'm not a fan of the ABT kit - their facelift kit looks good but the kit for the first gen with all the arch flares is a bit much for me. Plus it gets expensive having to paint the entire thing to match the car. Haven't priced it but would imagine that you wouldn't be left with much change from $5k if you were to run it through a crash shop.
    So I think I'm pretty much at the end of the road.
    Jun 2013
    Oh tigger! Don't worry if road ends. you may turn in to the Highway where you can find K04, Big brakes, WM Injection, Air suspension etc. Lol
    By the way I am also interested about Golf R style LED tail lights .. But I think they would not fit Tiguans..
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
  9. #379
    Nov 2007
    Still got to have an upgrade FMIC and a K04 in your future mate. Both will work beautifully on your DSG Tig and deliver you RS Q3 rivalling performance. Low 4s 0-100 and about 250kw/500NM .....
  10. #380
    Yeah I know but if I go KO4 then I really ought to get a BBK at the same time (if you go fast you really need to be able to pull it all up).
    I'll have to talk to the accountant about this one in terms of legth of time to keep the vehicle, $ for mods and then also what I do when I eventually come to sell.
    The other thing is that I'd rather not have big turbo lag - my preference is that have something that is quick/responsive on the street rather than a track car. So I'm a little undecided at this point.
