Page 32 of 101 FirstFirst ... 2230313233344282 ... LastLast
Results 311 to 320 of 1001
Thread: Tigger73's 125TSI Tiguan Build Thread
  1. #311
    APR Unit fits in perfectly - and it's almost twice the thickness of the original - all the mounting points are identical to the GTI / S3/ A3/ Octavia. The only mod we have to do is lengthen the hoses that attach it to the engine. Are you sure you are dealing with someone who has actually tried to test fit one into a Tiguan?
    I can't be 100% as I wasn't there but was told that the VAR inter cooler hangs down lower which is fine in the Golf but in the Tig this ends up hitting the plastics on the bodywork.
    I was told they had the front of my car off to look at fitting it and also that there is difference between the facelift Tig and first gen but this is not from first hand experience.
  2. #312
    We have fitted them to early & the late versions - the lower bit locates into two holes in the radiator support - it's identical to the Golf, so that cannot be an issue at all.
  3. #313
    OK here's the audio clip. Probably doesn't give a true indication how loud this is - system is non-resonated.
    This was a cool morning and the first 60 seconds the auto-choke is active. After that it quietens down... and then a couple of revs with a pop.
    Here's a photo from under the rear of the car.
    Tigger73's 125TSI Tiguan Build Thread-9691969446_4914079e46_z-jpg
    Arrawarra
    Hey t73, how are you liking it driving around town? Also like to get your thoughts on what it would be like out on the highway, once you get a chance!
    I got a 2nd - handie CAI i'm gonna install tomorrow & may go down the path of more exhaust mod's soon...
  5. #315
    Quote Originally Posted by MGV View Post
    You can drive it quietly around town - drive it in "D" and keep the revs under 2,500rpm and it's relatively docile.
    However give it a boot load and it is pretty loud.
    I have done about 1,000km of highway driving and there is no drone in the exhaust. You can certainly hear the exhaust note while cruising but it isn't intrusive. There is a fair amount of noise when overtaking and going up hills it is certainly louder than stock.
    I'm still waiting for it to soot up completely (1,500-2,000km) and after that it should be pretty much how it's going to be.
    ...though still considering getting a resonator fitted as I do use the car for business.
    Just a word of caution on installing any old CAI. The ECU is pretty sensitive with air flows and aftermarket CAI's can upset them (speaking from recent experience). I changed my CAI recently from one design to another this and caused all sorts of issues. Ended up reverting back to the stock intake and this fixed things.
  6. #316
    Jun 2013
    Oh so you are now running without the middle resonator? I thought without it would make a nasty drone.. Also any feeling of extra power with the new exhaust .. I guess improved sound will automatically add 10Kw
  7. #317
    Quote Originally Posted by Ramee View Post
    Yes exactly - middle resonator is gone completely (must have evaporated while I was driving). Just a pipe with a couple of bends from the cat to the muffler at the back.
    No drone at cruising speeds. HM Headers are making these for Viezu Australia under the VAR Design name. They are a major exhaust manufacturer and manufacture exhausts for HSV, Walkinshaw, Elfin as well as aftermarket systems for a lot of other cars. So they know a bit about making exhausts.
    I wasn't expecting any increase in power - just sounds like it goes faster now
    Adelaide hills, SA
    So, is that what had caused the scare?
  9. #319
    Yes had a new design intake installed and it didn't agree with things - performance was way off. So I've gone back to my stock intake for now and will hopefully get the old GTI/R style intake sent across and fitted back on shortly.
  10. #320
    Jun 2013
    Lol .. So you must be driving crazy fast than me or you can blame Vezu tune for making exhaust temp too high last time I checked my one was there Speaking of which did you get the new race tune yet?
