Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Tig will not turn off. (Demystified/Explained)
    Dec 2008
    Alexandra, New Zealand
    Quote Originally Posted by mikeinbris View Post
    Does this apply to TDI range?? The engine always continue to run for 30sec+ whenever we stop the ignition and the key pulled on. It seems to do this when the engine is warmed up. My friend who has a toureg has a engine does the same thing and i was told it's the engine is warming down in that case.
    so which side of the story is correct?? cheers
    REALLY ??????? your TDi Tiguan runs for 30 seconds AFTER you take out the key ?? NOT just the fans ?? If that's the case there's something definitely wrong with your Tig cos they don't have any form of turbo timer whatsoever. I've owned 4 new turbo diesels now and none of them came with a turbo timer fitted. With a modern system such as the Tig's there's no need for one unless you live in the country and go from hammering the heck out of it for many miles to "switch off", in which case it's probably better practice to allow it to spool down for a minute or so.
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Nov 2007
    Its been said here a few times now .... but just to make it absolutely clear .... the cooling fans can coolant pumps can and will run for up to a few minutes after the car is switched off and the key removed. These are all quite noisey but do not confuse it with the engine running.
    THE engine SHOULD NOT be running after it is switched off. If it does, there is a problem and a VW dealer should investigate. It is VERY unlikely to a turbo timer (99.999% actually) as these are not common to VWs.
    Sep 2009
    Brisbane, Qld
    Checked again last night, it's definitely just the fan that keep running after ignition's off, not the engine. sorry about the confusion there....
    Nov 2005
    LMAO at this thread! priceless!
    vw build there cars for there thermo fans to kick in after ignition and keys are out and when the temperature is at a set temp (hot), my 1977 mk1, 85 cabrio, and 92 passat all do this, its nothing out of the norm for volkswagen, and there is no such thing of volkswagen programming the motor to keep running after the keys are out the ignition
    dom
    Nov 2008
    QLD
    20 lashes for that - glad you got it sorted though
    Jul 2005
    nothing from the OP to say whether its been fixed?
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
    Dec 2008
    Quote Originally Posted by blutopless2 View Post
    Care to bet there was never anything to fix ? just somebody who can't tell the difference between the sound of an engine and a fan !!!
    Derek
    Alexandra
    Sep 2009
    Heidelberg, Vic
    To be fair it is bloody noisy....
    Aug 2009
    South Australia
    To be fair I think 99% of us knew i was the fan all along.Did serve for some amusement factor though
