Results 1 to 10 of 14
Thread: Tig airconnditioning
    Jul 2009
    Emerald , QLD
    the aircon on my 103TDI (with comfort pack = climate control) seems to have failed @ 50days , 4000k . AS I am 1000k from my dealer , am interested ti know , others experience with air con problems/performance, My doesn't seems to reduce air temp. but fan speed varies as you adjust temp.
    Otherwise very happy with my Tiguan
    Dec 2008
    Alexandra, New Zealand
    Assuming it's all switched ON correctly I can only assume you've lost gas from the system. HAven't heard of it with a Tig before but I had it happen with a Mazda Astina I had and it was just a connector that had worked loose. 10 minute job to fix BUT unfortunately in your case you're a long way form help. I guess all you can do is check that it IS all ON correctly, check there's no slack in the compressor drive belt and then just wait till you're in a position to get it fixed. Bugger
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Jul 2009
    Emerald , QLD
    g'day,
    thats my guess as well, might have to pay to have a local check the gas and connections , probably cheaper than trip
    Ted Hagstrom
    2009 VW Caddy, Whte, TDi, DSG
    2009 Tiguan, silverleaf, 103Tdi ,auto, Comfort pack, leather, fogs, Rns510 with RVC
    Aug 2009
    North Coast, NSW
    This happened twice on my Polo Gti, at about 10,000KM and again at 40,000km
    on a 30c day driving for over an hour would not cool the cabin.
    The first time it happened they replaced the compressor and re-gassed and added dye to the gas.
    Checking after there was a lot of bright green residue under the hood, at first i thought i was coolant, then remembered thats its red
    Second time they patched the leak and re-gassed
    First time car was in dealer for 2 days as they had to replace compressor then get the radiator guys to flush the system and re-gas.
    Jul 2009
    Emerald , QLD
    Unhappy
    Have had a good local mec hanic have a check of the system , gas levels are ok . Unfortunately his diagnotictools would not access the vW computer.
    Have order the Ross-Tech cable from the states expect to arrive tomorrow . Also have subscribed to www.erwin.volkswagen.de
    will check for error and sensor readings -hopefully will tell me whats really happening
    Ted Hagstrom
    Dec 2008
    Quote Originally Posted by Tedhaggie View Post
    Stranger and stranger !! will be interesting to see what you find in the end, at least it's a warranty job if it's something major !!
    Derek
    Alexandra
    Jul 2009
    Emerald , QLD
    Got the diags loaded on my laptop and connected . . Evap temp 25 ambient 23 - concluded it was gas afyter checking all measuring blocks . added 100g gas - evap temp to 5 and cool air but unfortunately this morning no cooling - evap back to 25, gas has gone- couldn't locate any leak with detector yesterday may try again today
    Ted Hagstrom
    Dec 2008
    Bugger !!! well at least you KNOW that there's a leak somewhere, now all you got to do is find it !!! Maybe time for "Torn's" idea of putting dye in with the gas so you can track the leak ?
    Good luck
    Derek
    Alexandra
    Jul 2009
    Emerald , QLD
    Wiil be testing this afternoon used gas with UV dye yesterday. Hopefully locate leak. then down to war with the dealer. I know of other dealers in Qld using "agents" to carryout work for remote clients
    Ted Hagstrom
    Dec 2008
    Certainly here in NZ, as long as it's an obvious warranty issue they usually don't mind local firms doing the work (our nearest VW agent is 200k away) providing they've approved it first.
    Derek
    Alexandra
