Hi mate
Yes the tongue of the towbar can be removed.
Up near the locking clip[which you also remove] there is a lock nut which you have to ease off with a small shifting spanner or crescent.
Put some upward pressure on the actual tongue [to release tension] then pull out the locking circlip and then juggle out the retaining bar that's sitting in the drilled hole in the upper tongue.You should then be able to pull down and completely remove the whole tongue and towball.To refit just work in reverse but dont forget to tension up the locknut after the whole thing is back in place.
Phil
Candyweiss 2010 TDI Dsg 7 speed box.Headlight covers,weather shields,mudflaps front and rear,towbar, led parkers,Nudge bar with Liteforce spots, Rhino sports roof bars.Rear side curtains and so it goes on.Now with R mfsw with paddles.That's it folks.
Beautiful Honda VTR1000 Firestorm,black as.
