Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 139
Thread: Thomas the Tig
  1. #21
    What bit rate did you use when you converted your files? Do you have the ownér's manual for the RNS510? if not you can download it from the Skoda portal, the link is in the Skoda section (the radio is called Columbus but it is the RNS510).
    They are all varied but all under 320kps, with the majority being 160kps. The same process occurs whichever song I select regardless of the bit rate. I have the manual, however, it has not offered any solutions on my reading. Thanks for your help, I'd still love if someone could offer me the solution to this conundrum.
  2. #22
    Boot liners. I had one in my 2002 Polo and it was fantastic. I decided not to order this part through the dealer after discovering via this forum the linked website. Can anyone advise if they have purchassed one of these and which one would be the most appropriate for a 2011 Tig.
    Shop4Volkswagen | Tiguan - Protection
    They talk about a raised load space or raised load space, which is appropriate for our Australian Tigs? I'm guessing the raised as it has to do with the spare tyre?
  3. #23
    Jul 2010
    Quote Originally Posted by ralp2dam View Post
    Yes ... your guess would be right!
    Whilst purchasing from UK dealer makes sense most of the times.
    It's probably not the case for bulky/heavy items (like boot liner).
    But by all means, get a quote for shipping!
    If you still go ahead, then I definitely suggest making the most of shipping cost by including some other small items into the order.
    MY11 Tiguan 147TSI (SOLD)
  4. #24
    Quote Originally Posted by aussietig View Post
    It's probably not in the case for bulky/heavy times.
    Thanks. I'll look into the cost and let you know how I go.
  5. #25
    Oct 2009
    Mitchelton, Qld
    I just got one from these guys. Works a treat.
    Cargo Liner Boot Mat: VW Tiguan (Nov 08 to Curr) 5Dr Wagon: 40387
  6. #26
    Quote Originally Posted by donweather View Post
    Great. Thanks for the link.
  7. #27
    This is a re-post from the RN510 thread as I still need an answer please.
    Question to the wise. I have the factory fitted RNS510 and have copied via SD card my music collection. I converted it to mp3 format prior to doing this. The music plays however, each time I open a folder to play it, it states words to the effect "can't read file". It then proceeds to cycle through each song before it plays normally.
    I can stop the car and resume playing from the same folder and this process does not occur. However, the same process occurs again when I go to a new folder. How can I fix this?
    I apologise if this has been covered before.
    This is the error message I was referring to below.
  8. #28
    Mar 2011
    sydney
    what firmware do you have on the rns? reason i ask is because i couldnt read sd cards greater than 2gb in mine before upgrading the firmware... now its fine, but i havent had your error message before.
  9. #29
    Jul 2010
    Quote Originally Posted by hippyhippy View Post
    His problem's not with the SD card. The files in question are on his HDD!
    I've come across this before and couldn't be bothered fixing it!
    Have my music library playing from a classic ipod via MDI with no problems whatsoever!
    But if I had to guess, it's something to do with the file name or each folder can't contain too many songs.
    Google "folder structure or restriction" for possible solution to problem.
  10. #30
    Still haven't resolved my above problem with music playback.
    On a side question, should the Tig come with the bottle opener in the centre console between the cup holders? I can feel a grove which I guess is a generic VW part that would allow it to slide into.
