Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 121 to 130 of 139
Thread: Thomas the Tig
  1. #121
    Deleted.
  2. #122
    Ellenbrook W.A.
    Hi mate
    Yes the tongue of the towbar can be removed.
    Up near the locking clip[which you also remove] there is a lock nut which you have to ease off with a small shifting spanner or crescent.
    Put some upward pressure on the actual tongue [to release tension] then pull out the locking circlip and then juggle out the retaining bar that's sitting in the drilled hole in the upper tongue.You should then be able to pull down and completely remove the whole tongue and towball.To refit just work in reverse but dont forget to tension up the locknut after the whole thing is back in place.
    Phil
    Candyweiss 2010 TDI Dsg 7 speed box.Headlight covers,weather shields,mudflaps front and rear,towbar, led parkers,Nudge bar with Liteforce spots, Rhino sports roof bars.Rear side curtains and so it goes on.Now with R mfsw with paddles.That's it folks.
    Beautiful Honda VTR1000 Firestorm,black as.
  3. #123
    Quote Originally Posted by philsan View Post
    Hi mate
    Phil
    Thanks again I'll give it a go later. The dealer said if connecting lights that are LED this will throw up a light out warning on the dash. He said ignore it there isn't any problem. This sounds funny to me bit he assured me it is normal. Does this sound right to you?
  4. #124
    Ellenbrook W.A.
    Good day to you again mate,
    Yes the dealer is correct in that if you hook up to any towed vehicle be it box trailer, boat trailer etc and they have led stoplights/indicator lights it will throw up a bulb warning on the mfd.There is a way around it[and your dealer should have alerted you to the fact] that there is another wizz bang electrical box[the name escapes me at the moment] that could have been wired into the towbar electrics to negate this error message,but once again it involves parting with another 200 or so smackos to have it installed.
    The alternative is,just ignore the error message as the dealer advised you.Unfortunately most trailers etc these days have the led setup.
    Phil.
  5. #125
    Phil.
    Thanks yet again Philsan! You're a wealth of information.
  6. #126
    Ellenbrook W.A.
    ralp2dam
    No worries mate.
    Only learnt by my own experience and doing the hard yards myself.I fitted my own genuine towbar but as yet it hasn't been wired up.Wiring harness still sitting coiled up in the lower r/hand wheel internal storage area.
    Maybe you can offer me a bit of advice! Do you know how the dealer went about wiring in the towbar harness on yours.
    I didnt get the genuine vw harness due to exorbitant price charged the dealer,rather went thru aussietig's advice and purchased another european harness that's basically the same as vw's but half the cost.I am very hesitant about doing this job myself as I am told by a vw independant service place that the whole r/hand interior panels have to be removed to run the wiring in the proper channel up to a place behind the dashboard.I was later told by another vw dealer that my model Tig 2010 and beyond is part prewired for the towbar and the final hookup place for the wiring is under the hard cover on the left hand side of the internal boot.
    Do you know if your dealer utilised this part of the factory prewire.It would make the job a lot easier to run the harness to this point rather than having to take all the other panels off on the opposing side.
    If you can throw some light on it,it would be appreciated.Tks mate
    Phil
  7. #127
    Jan 2012
    Sydney, Australia
    Quote Originally Posted by ralp2dam View Post
    VW towbar for $1465 installed. How does it compare?
    Really good pricing, where from?
    MY12 Tiguan 132TSI + DSG
  8. #128
    Z1000. I went with Denlo Parramatta. I ordered the part then for them to fit after getting quotes. See above.
    I obtained a couple of quotes for having my towbar fitted. I thought I would share this for anyone who goes down the route of having a dealer fit a towbar to a Tiguan.
    Parramatta: Total $502 - Labour per hour $143 - Hours of work 3.5hrs
    Sutherland: Total $649 - Labour per hour $163 - Hours of work 4 hrs
    Liverpool: Total $640 -Labour per hour $160 - Hours of work 4hrs
    Sutherland: Total $487 - Labour per hour $139 - Hours of work 3.5hrs
    Campbelltown: Total $528 - Labour per hour $151 - Hours of work 3.5hrs
    Waitara: Total $- 653 - Labour per hour $145 - Hours of work 4.5hrs
    For the astute reader Sutherland is listed twice. Sutherland responded twice to my email with two different prices. Hmmmm.....
  9. #129
    Jan 2012
    Sydney, Australia
    You know what, after I picked up the car from Denlo Parramatta, I enquired about the tow bar and was quoted $2700 all up, so I just drove away and never gone back....... actually I did go back, get them to rectified a broken A pillar trim, and replaced a faulty cd player.
  10. #130
    Quote Originally Posted by z1000 View Post
    That is outrageous! I only went dealer as I didn't think anyone else would have had much experience. Not that the dealer most likely had much either. I still think the way to go is order parts then have them fit it. If you look above a posted a link to a VW install guide for time whichever give you some control when they tell you how many hours labour.
