Hi Mate.
I will have a look at mine tonight and let you know.
Which lights are you talking about by the ay, the inner cluster (in the tailgate) or the outer cluster (in the bodywork)
If they are hte inner lights you just have to pull the little plastic door voer thing off then you have 2 screws to undo and it should come out.
The outter cluster only has the 2 black screws on the inner side of the bodywork then you pull it straight out and it should be fine.
It should explain this to you in the manual as you need to do this to change the tailight bulbs from memory.
