Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Tangles MY15 132tsi
  1. #21
    Jan 2020
    Finally fitted a superpro HD rear swaybar I found on sale late last year. Tightens up the rear body roll significantly. I feel it will eventually require adjustable links. I found a near new Golf R intercooler, so I have that to install....Then I'll get around to having a DSG tune loaded.
  2. #22
    Jan 2020
    51000kms now, all fresh fluids throughout (engine, awd, dsg, a/c, radiator) & fresh S3 Intercooler installed. Has IE 98ron ecu Stage 2 tune, 3" catted downpipe, k&n pod.
    Looking to see where everything is at currently so I (finally) took it in for a run on a Mainline 4wd dyno. 166awkw / 223awhp @4750 in 4th. Running slightly rich but overall pretty healthy. With ~20% drivetrain losses that equates to around 200kw / 267hp at the engine, a bit up from the advertised 132kw / 180hp. Noice. Fun to drive.
    Needs tcu tune (will go with TVS stage 2+). Awaiting an engine strut brace to arrive, and need to install turbo muffler delete & intake manifold spacer, plus think about a 2.5" catback system afterwards. Then dyno again. Sweet.
  3. #23
    Jan 2020
    72,000kms, all going well.
    In 2023 I got Laborde Motorsport to flash the TCU to their stage2 Sport settings, and the 7spd DSG has been fantastic since. D-mode gets it wrong on my local hill (should be 4th but wants to go to 6th) but S-mode, with the Passat paddle shift steering wheel, is perfect. Cant fault it, exactly how it should have been from factory.
    Just installed a K04 HPA hybrid turbo 2 days ago with the help of a mobile mechanic. Was a hot 39deg day, but got it done. Fits perfectly, however Ive now lost boost reading to my boost gauge. Line comes off the intake manifold. I haven't looked into it yet, just test driving and enjoying the IE Stage 3 K04 tune I flashed on afterwards (eventually, lost signal after the erase procedure so had a fright there that's for sure). The Tiguan is manic now, pulls hard through the gears with wheelspin in 3rd gear. Awaiting an upgraded CTS engine mount to hopefully help a bit.
    I'm expecting the 2.0tsi EA888 gen.2 engine should now be north of 330hp, I'll get it onto the dyno soon-ish but first need to do some datalog runs in 3rd on a straight out-of-the-way country road. So far so good.
    Tiguan 5N 132tsi, DQ500 7spd DSG, AWD, towbar, 72000kms
    Fresh fluids & filters throughout (coolant, fuel, cabin, A/C, brakes, engine, AWD, DSG)
    HPA K04 hybrid turbocharger upgrade
    Stage 3 ECU tune with Integrated Engineering (IE K04 tune)
    Stage 2 TCU tune by Laborde Motorsport
    Passat CC paddle shift steering wheel
    Newsouth Performance boost gauge
    Audi RS redtop coilpacks with BKR7EIX .027” sparkplugs
    Audi S3 front mount intercooler
    Spulen chargepipe intercooler hardpipe kit
    K&N pod air filter, custom air intake setup
    GFP DV+ diverter valve
    HPA 3” turbo downpipe with hi-flow cat, into Racecraft 3” resonator
    X-force 2.5” round mid-muffler, Racecraft 2.5” oval end-muffler
    ECS Front stainless steel brake lines
    Front 312mm slotted rotors & Bendix ultimate pads
    Speedbleeders front & rear, 600c fluid
    USP Rear stainless steel brake lines
    Rear 282mm DBA T3 4000 slotter rotors @ RDA extreme pads
    Eibach lowered springs
    Hardrace front strut brace
    Superpro rear adjustable swaybar links
    Superpro 24mm rear swaybar
    Superpro torque arm bush kit
    Metal torque arm brace
    Superpro front lower arm block bush kit
    Bartek HPFP upgrade with new roller collar bearing
    Ross-Tech VCDS / IE Flash Wizard
    To Be Installed
    ECS intake manifold spacer
    ECS Engine mount upgrade
    Deatschwerks DW300 fuel pump
  4. #24
    Wow you haven't held back with the mods. I bet you are loving the HPA K04 turbo upgrade, these engines really sing along with the K04 and with the Tig you have grip in just about all situations. This would be a fun little daily. Have you got any photos showing the car and mods?
  5. #25
    Jan 2020
    Just had a good test drive in the Hills, the K04 is very fun indeed when it comes on boost. So buttery smooth but pulls hard to the redline. In all honesty, it looks dead stock just sits slightly lower on the factory 17" rims, with a slightly wider stance due to the wheel spacers. I'm 6'8", could do with a lower & grippier seat but otherwise it suits me well.
    I get bits here and there when on sale etc. and do the work in my carport. Keeps me busy on a project or two. Looking for a set of Tein, Koni sport, or B6 Bilstein shocks next.
    But first I'll get it onto a dyno, and then out for a run on the sole drag strip that's just opened in Adelaide (The Bend, SA). Perhaps a track day too.
