MY15 132tsi brakes
Yes air intake is similar to Mk6 Golf. There are some slight differences where the intake connects to the front grille if the intake you’re looking at does this (e.g. APR) as there’s slightly different brackets.
Otherwise if you’re just running a covered pod filter most should fit.
It’s important that the pipe sizes are same as OEM otherwise this can throw out the MAF reading. Although oversize air intake pipes will reduce restrictions, they also screw up air flow readings so best to stay with stock sizes.
- You may not post replies
- You may not edit your posts
Forum Rules
