Rear bar is different between 2WD and 4WD models. Maybe someone boxed the wrong one.
Had my Tiguan into Fulcrum suspension today for fittment of the RC0006RZ-26 Rear Sway Bar as below,
26mm Heavy Duty 2 Position Blade Adjustable Sway Bar
I was also getting two new SuperPro Rear Sway Bar Links fitted at the same time to improve the rear of my Tiguan.
The sway bar is 10mm too wide and interfers on other parts of the suspension.
My Orginal sway bar was refitted without any issues and Fulcrum are in contact with SuperPro in Brisbane to work out what is going on.
Has any one had this issue before?
2015 Tiguan 132Kw 4Motion
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
I really hope it is that simple of an answer.
I am in Canberra this week coming for work.
So it will be another week before I check in with the Fulcrum and see if they have any answers.
