Results 11 to 20 of 21
Thread: Sometimes, its just the little things that count.
    Jul 2011
    My 2 cents on dealer set tyre pressures. Mine were all equal, but in the mid 40s. Well over the specified maximum pressure.
    MY20 Golf 7.5 R - Blue
    Jun 2009
    Quote Originally Posted by epicmac View Post
    I thought the maximum tyre pressure was 50PSI?
    Canberra
    Quote Originally Posted by team_v View Post
    V, you are a classic. I have been reading the whole thread on your Tiggy for the last couple of days. Currently up to Page 45 and enjoying every second. I have ordered the led internal globes, am contemplating removing all of the id badges and have also ordered the nanolex. God knows what else I will find in the remaining six pages.
    I will be getting the flash done, it is just a matter of when.
    Epicmac
    Who knows what the dealers do. I am just pleased I read the forum and new to check on the pressures
    Cheers Gentlemen
    Jul 2011
    My 2 cents on dealer set tyre pressures. Mine were all equal, but in the mid 40s. Well over the specified maximum pressure recommended for a non fully laden vehicle with my particular sized tyres on it. Better?
    Actually, checking my notes, fronts were 46, rears were 48psi, and I noticed when I was adjusting the pressures the dealer/factory air was very sweet smelling.
    Jun 2009
    Ahh okay.
    I know that the reccomended max for mine is 51PSI
    I normally run the fronts at 38 and the rears at 36 for regular driving.
    From memory mine were at 40 when i got them however they are shipped with close to 50.
    Arrawarra
    Quote Originally Posted by mutare 23 View Post
    From reading items on this forum, there is a suggestion that the APR flash etc., can be 'hidden' from the dealers. I find this to be rather hard to work out, as surely there would be a recording program within the ECU that would indicate to any boffin who has the right equipment if the vehicle is running over standard boost, or richer fuel mixtures, or really anything that isnt standard??
    Mutare 23, the APR tune i bought around 9 months ago for my '10 Tiggy gave me the ability to switch back to the stock mode at any time using nothing but the cruise control toggles, then lock the ECU in that stock mode so that is the only thing 'visible' when the ECU is accessed by VW diagnostics is the stock fuel/boost/etc maps. Once the ECU is locked, a PIN is needed to 'unlock' for access to the performance tune.
    Canberra
    Quote Originally Posted by MGV View Post
    MGV
    Thanks for this. I am aware of the ability to be able to switch programs and the security code (PIN), it just seems strange to me that the main computer that will be doing the diagnostic work, wouldnt be able to detect over boost, changed fuel use etc. My understanding was that the ECU had a diagnostic support system. Will be more than pleased if nothing of an APR can be flashed, but I reckon computer boffins would be able to locate it.
    Thanks again
    Jan 2008
    Sunshine Coast
    Afraid no time is any different despite what you have been told, some are better than others, but no one is undetectable if the effort is taken to find out. Viezu claim all this undetectability, but as it varies massively from marque to marque, and nothing is undiscoverable to the right prying, best to just say if you are tuned,and the dealer has need to look, they will find out. Reality is they usually don't bother.
    Canberra
    Quote Originally Posted by Greg Roles View Post
    Greg
    Thanks for this. I kind of thought that the dealers wouldnt look too hard unless there was a reason for doing the same. I intend to keep my Tiggy looking very stock, with no indicators of the APR when I have it . Hopefully that will result in no attention from dealers, blue lights or anybody else for that matter.
    Jan 2008
    Sunshine Coast
    You don't have a Viezu dealer in Syd/ACT as yet, but for the record, some of the major difference I felt in the Viezu tuned Tig was the DSG alterations making it more smooth and responsive, something only Viezu can do from an engine ECU only reprogram at present. Assuming you have DSG of course!
