Results 1 to 6 of 6
Thread: Something In The AC Has Lot Its Mind
    Oct 2015
    Melb, SE Suburbs
    Hi all,
    Has anyone heard of AC vent controls going haywire?
    Buzzing, flicking, ticking MANY times a second under/in the dash... Like a relay endlessly trying to do something, but failing (wild guess).
    The only other AC related issue, might be connected... AC does nothing, and occasionally throws a fault on OCD for last 5+ years. IIRC, back then, I could only get AC working if I did things manually, not auto/climate control.
    Car is kinda damp/smelly. Windows always fog. Tools in the boot always rusting.
    I'll try upload a video to youtube
    Mornington Peninsula, VIC
    A bad blend door motor will most likely cause the noise you mentioned; when the position sensors fail on them, they will open and close on repeat.
    You can use a scan tool to work out what motor has failed and then replace it based on the erWin guide or a similar online guide like here Volkswagen Tiguan Service and Repair Manual - Adjustment Motors - Air Conditioning
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Pacific Paradise QLD
    Has it got a sunroof and if so have you ever cleaned the drainpipes and removed the spider traps
    Oct 2015
    Melb, SE Suburbs
    Thanks for the comments.
    Sorry for not replying, personal issues.
    No sunroof.
    I reckon it sounds like that blend motor thing. Surprised it hasn't burnt itself out, or tripped a fuse etc.
    My mechanic gave me his legit scantool to play with, while sitting in his driveway. All I could find was intermittent AC code showing. Gave no real info, and after resetting, it didn't return while there. Not sure if/when it does.
    Thanks for the link, I'll read-up
    It will almost certainly be the blend door motor/actuator. I just replaced one on my brothers car (Skoda) a few weeks ago. The housings fall apart and then the little gears start slipping and stripping and make that horrible noise.
    Dont buy a cheap Chinese ebay or Aliexpress version as they just dont last. Get a genuine VW one.
    Oct 2015
    Melb, SE Suburbs
    Dreading the job, but really appreciate the solid info, thanks!
