Results 1 to 10 of 61
Thread: Side steps for Tiguan - Possible Group Buy.
    I might be able to take delivery? Where in Sydney is everyone who wants one?
    Regards,
    2011 Mountain Grey Metallic/Vienna Trim Tiguan 147TSI , 18 New York Alloys, RNS 510, Park Assist and RV Cam.
    I'm up for one.. in north shore sydney, or parramatta area.
    Jul 2010
    Quote Originally Posted by BigTig View Post
    LAST CALLS FOR A SYDNEY GROUP BUY ONLY
    In order to get the ball rolling and finalise numbers to submit a shipping quote, I'm gonna suggest an absolute deadline of 10.00am this Friday, 27th August to register your interest.
    So far, I believe the following members are interested:
    1. BigTig
    2. Nobita88
    NOTE: By "interested", I mean seriously prepared to pay up to $283 USD + share of the bank charges for a T/T
    So if that's still you ... then could I please ask that you just copy the last list that you can see in this thread and add your name to the bottom of that list. Then on Friday morning, I'll just return to this thread and go with the final list.
    Thanks!
    Just did some search from past threads and am a bit concerned about the jack. Is it confirmed that the original supplied jack can't be used when the side steps are fitted?
    Jul 2010
    Quote Originally Posted by Nobita88 View Post
    C'mon mate, don't let practicalities get in the way of an emotional buy!
    If we all like that then nobody would be buying iPhone 4s.
    Besides ... we're all Tiguan owners! As if you let the size of the pathethic boot deter you (whilst every weekend you reassure your nagging wife that it's not a hassle at all, loading and unloading the second pram off the roof racks).
    Anyhow, I think Transporter's the authority in this area!
    Adelaide hills, SA
    Well you, probably will have to take the step off, in order to use the factory supplied jack. How ever that is relatively easy done, at least on the steps that came with our Tig. The instruction say that you need to only lose 6 bolts (M6x1) in the aluminium. step, since the holes are open, so 1/2 turn only on each and slide the step 1cm or less forward that will allow the step to be lifted up, it may take 2 minutes if you're not handy at all.
    Step from the road up. Showing 2 bolts, there are 3 brackets holding aluminium step.
    The other option is get different jack and get familiar with floorplan of your Tig to get to know where are the alternative jacking points.
    On happier note: It's not something you will do too often.
    I had to replace flat tyre on the road once only on our last car that we had for 11 years.
    Aug 2006
    Far North Qld
    aussietig
    sorry for not responding correctly to your question regarding Sydney group buy only...
    I'm not a SYDNEY buyer but..., at Sydney prices plus freight to FNQ I would still be interested...
    cheers
    Tigga1
    Jul 2010
    FWIW, each step is also held on with 6 bolts also to 3 brackets.
    Pictured below is just 2 of 6 sliding washer/nut on the rear underside of the step.
    So I'd imagine in a worse case scenario, you'd undo the 6 bolts to remove the step altogether, with the 3 brackets still left intact.
    Adelaide hills, SA
    Quote Originally Posted by aussietig View Post
    Pictured 2 posts above is just 2 of 6 sliding washer/nut on the rear underside of the step.
    Or maybe there are slots in the brackets.
    If not, then maybe that is something that can be done, to speed up removal (2 small cuts with the hacksaw).
    Jul 2010
    Quote Originally Posted by Tigga1 View Post
    aussietig
    I reckon you'd be in front, if you went about alone and have it shipped directly to FNQ.
    But I guess there's no harm seeing how much would be your GB share of the total cost.
    However, you'd definitely have to organise the courier pickup from the designated GB address [TBC].
