I put my drain plug in the lathe and drill the hole in it for magnet going inside, alternatively you can buy magnetic drain plugs over the internet.
That's interesting cos they don't run any special running in oil in them in NZ ?? and presumably they come form the factory basically full. My agent put a litre container in the boot as the diesels are known to use a little during their first 10,000k or so but mine didn't need it at all.
Derek
Alexandra
2022 R-Line Golf Mk8 in Kings Red Metallic
Previously 3 Tiguans 2008, 2013, 2017
Surely your lack of mechanical problems aren't purely because you have done more frequent oil changes?
A) How much of the engine is Ferrous metal these days.
B) Isn't catching contaminants the filters job?
C) The Magnet would do something, but all that ferrous is already in the filter - why not let it go through to the keeper (the filter material)?
Buggered if I know what all this long term damage is. I used to look after a fleet of 10 Ford/Holden/Chrysler courier vehicles, which did 100,000km a year (then we turned them over). The services were by the book. The drivers didn't warm them up & gave them a hammering. We never had any issues with engine related wear / lubrication issues. Our biggest dramas were auto transmissions, brakes, cooling systems (that's an item that needs a good flush out) & steering components. The same with our 1 tonne ute fleet - engines good, clutches & brakes bad.
I didn't say it was solely because of that but it certainly helps, especially with older engines. It's just one part of a preventative maintenance program that will always lessen the amount of mechanical issues you would experience, ask any mechanic. You turned your fleet cars around every 100 000kms so you would be unlikely to see any serious wear issues by then.
The magnetic sump plugs are a better idea than the filter magnet IMO. When the oil settles into the pan when the engine is at rest there's a greater chance of a magnetic sump plug catching someting there than when the oil is flowing through the filter at speed I would have thought. Plus the heavier stuff may not even make it to the filter?
Forever blowing bubbles.
Brad,
Next time I change my oil in T5 I take a picture of the magnet in that drain plug. Just for the record not all oil is filtered through the filter 100% of time and you know it.
The biggest friction area in the engine is cylinder walls (made of cast iron) scraped by piston rings and that is what get caught on the magnet.
It is a little bit different when the vehicle does 100,000km. In that case you can change oil every 25000km and everything should be allright.
Hi Guys,
just want to get some opinion
my first service was scheduled on 7500km, should i follow that or ignore it and go straight to 15000km or 1 year (i believe that is the service interval for tiguan)
cheers
It all depends if you drive under severe conditions or not and how long do you want to keep your Tiguan for? I usually keep my cars for long time so I service them every 5,000km - 7,500km.
I found it a bit of a waste of time. They don't do much more than a fluid check and make sure there are no big problems. It is an optional service, and if you've been keeping an eye on things you should probably be OK.
Tiguan TDI, 6spd Tiptronic Auto
Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
Avg 7.63L/100km over 189,000kms
