Results 1 to 10 of 13
Thread: Sealant - Water pump.
    Aug 2017
    Brisbane, queensland
    Hey guys im still getting use to these rubber gaskets but I want to double check.
    For my water pump do i require any sort of sealant
    In the pictures provided
    Screenshot by Lightshot ( water inlet pipe/coolant pipe )
    Dec 2008
    Sydney/Canberra
    No, just make sure the surfaces are clean.
    As for o-rings on pipes, some silicone spray helps with installation and sealing. Don't use grease or vasoline. It'll react with the rubber.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2013
    Brisbane, QLD.
    Quote Originally Posted by Umai Naa!! View Post
    Spot on. Sealant big no no, just will block everything.
    Aug 2017
    Great fellas thank!! Use to my landcruiser
    Kotara NSW
    Hi, our MY12 132 is leaking small amounts of coolant, intermittantly. Maybe 100ml a week. And out onto ground, not into engine. Just had 90k service and all was fine. Took it to local repairer today, couldn't find a drop, but found coolant stains on underbody tray towards front. Maybe it leaks most when cold, sitting in garage judging by the small wet patches on floor. Garage guy said it could be anything from head to pump or hoses, but cannot tell without an expensive take apart. So suggested living with it until something worse happens.
    Anybody had similar?
    Dec 2008
    Sydney/Canberra
    Put it under pressure and look?
    Water pump is at the front of the motor under the intake manifold, at the gearbox end.
    '01 Beetle 2.0
    Kotara NSW
    Thanks Umai, that's one of the things the guys did today as thought it might be header tank or radiator core. Couldnt find a drop. Didnt leak for them when running hot or cold or stopped. Topped it up to top line in bottle last week, now just under minimum level and damp garage floor. I might leave it at that level and see what happens. Maybe a hose pinhole thing.
    Kotara NSW
    Just checked a bit more myself. The big lowest radiator hose drivers side just under the belts and pulleys feels very soft and empty - or is that some sort of air hose? Goes to a corrugated molded plastic thing that goes to big metal inlet right rear of engine.
    Dec 2008
    Sydney/Canberra
    That's one of the boost hoses for the turbo system.
    '01 Beetle 2.0
    Kotara NSW
    Happy it doesnt seem to have coolant in it then! Two other questions.
    1: The service guys filled it with green coolant - a few vids online say use the VW pink only...does it matter?
    2; The reservoir bottle hoses have crusts around the hose inlets. Is that a potential problem - I mean if there's crust there maybe there's more elsewhere. VW make it so bloody hard to see anything and I can't get it up on stands at my place so have to rely on mechanics - who obviously don't want to spend half a day taking it apart to find a loose hose clamp.
    It isn't overheating and oil is clear as is coolant, so I think I'll leave it and see if it gets better or worse...
