Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Anyone had their Tig dyno'd?
    Jul 2007
    Canberra
    Hey all,
    Was just wondering if anyone has had their Tig dyno'd? If so, you would have to use an awd dyno but would the 4motion system give you funky readings because of the torque transfer etc?
    Simon
    Forever blowing bubbles.
    Nov 2008
    QLD
    Quote Originally Posted by Pullstarter View Post
    There's one in Melbourne somewhere that can do them.
    May 2009
    Western Sydney, NSW
    Blog Entries
    1
    I'm seriously considering getting my Tig Dyno'ed at the Sydney Dyno day Fuzion has organised. Will be interesting to see the results and whether the AWD makes a difference.
    Tiguan TDI, 6spd Tiptronic Auto
    Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
    Avg 7.63L/100km over 189,000kms
    Nov 2007
    Actually you don't need an AWD dyno for the Tiguan. Pull a fuse out (or unclip a connection) and its FWD only ..... thats the benefit of the 4Motion system since its only a "make believe" AWD ....
    Guy knows which one .... so some info here Guy please ....
    I believe running on a AWD dyno will only confuse the dyno as the drive to all 4 wheels is not constant or the same.
    Jun 2009
    I would be wary about that.
    I believe there was a fuse-remove on an S3 and it was linked to a few other vital parts which made the car not work.
    Would be okay if the fuse is only used for the 4-Motion control.
    Nov 2007
    Quote Originally Posted by team_v View Post
    The Tiguan's that APR did their development work on (including clip's) all were running on a FWD dyno only .......
    Maybe Guy can post clip's dyno results up for us to see ......
    Jun 2009
    Okay, sounds like it should be fine.
    I was just warning incase any DIY'ers try it and then manage to destroy something in the process.
    I would check with Guy and your owners manual before doing anything like that first.
    For Dyno testing it's fine to unplug the Haldex unit converting it to FWD.
    To the best of my knowledge, there is no fuse to pull on these cars, but unplugging it is a 2 minute job under the car.
    You need to clear fault codes after unplugging it.
    Saves any of the dyno associated kick in / out of the AWD system.
    Jul 2007
    Canberra
    Thanks for the info guys. Only problem is if it throws codes will I be able to drive it to my mechanic to clear them after (no idea if the dyno place would have vagcom) or will it just not go?
    Adelaide hills, SA
    You will be able to.
