Results 1 to 10 of 12
Thread: Rust on discs after car wash
    Jan 2012
    Eastwood NSW
    Is this normal? Gave the wheels a good spray and within 2 days, all 4 discs are now badly rusted!
    Sep 2006
    West Sydney
    It's just surface rust. Have a drive around the block and your normal braking will grind back the rust and the rotors will be shiny again.
    Sent from my iPhone using Tapatalk.
    Mar 2008
    Sunshine Coast
    Take one of the wheels off and see the rust on the hub !!!
    You will quickly forget about surface rust on the discs
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
    Mar 2011
    sydney
    that is perfectly normal .. in fact.. after spraying the disc, there will be rust within the hour.
    Jan 2012
    Eastwood NSW
    Thanks so much for your quick replies. I contacted VW and they confirmed it too. At least my missus won't be having any more kittens!
    Apr 2011
    Eastern suburbs, Victoria
    I found that if I washed the car and didn't move the car till the next day the brakes seize. Makes a definate bang when they free up when I move the car. Now I always take it for a quick spin to diperse any water from the brakes. First time it happened I siht bricks.
    Golf R, Rising Blue, 5 Door, DSG and some extra fruit.
    Viagra on 4 wheels !!
    "If you can't fix it with a hammer then it must be an electrical problem"
    Mar 2008
    Sunshine Coast
    Don't put the handbrake on
    Assuming your parking spot is level
    Apr 2011
    Quote Originally Posted by Candyman View Post
    That's an option. I take it for a spin as a pre inside wheel clean these days so doesn't happen anymore.
    May 2011
    Albury, NSW
    Every VAG I've ever owned has done this, worried me at first like yourself but the dealer pointed out even the cars in the showroom had it. Something you'll get used to!
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Jul 2010
    Get use to it.
    Will also happen when you're car is parked outside under heavy rain.
    MY11 Tiguan 147TSI (SOLD)
