You're in luck mate! Managed to keep and find my last scan.
Anyhow here's mine, but also with all its last ailments:
Code:
Saturday,26,March,2011,13:28:58:27742
VCDS Version: Release 10.6.3
Data version: 20101206
Chassis Type: 7N0
Scan: 01 02 03 08 09 10 14 15 16 17 19 1C 22 25 2E 37 42 44 46 4F
52 53 55 56 62 72
VIN: WVGZZZ5NZBW046041
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Not registered 0011
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 AT HW: 5K0 953 569 B
Component: LENKS.MODUL 009 0136
Revision: FF010038 Serial number: 20100923201379
Coding: 1892140000
Shop #: WSC 01324 020 00200
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS_VW36.rod
VCID: 7EDD376E5071
MFL:
Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H06 0010
Coding: 830000
No fault code found.
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5N0 920 872 HW: 5N0 920 872
Component: KOMBI H20 0420
Serial number: 00000000000000
Coding: 110F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: EFC39A2A871B
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H25 5603
Revision: H25 Serial number: 170910F2002085
Coding: FDAB7F0600121300006003
VCID: 2E7DC72EC091
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 17
Mileage: 3723 km
Time Indication: 0
Date: 2005.14.15
Time: 11:49:58
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Component: SG EXT.PLAYER H13 0111
Revision: A1001003 Serial number: 7668661411
Coding: 010000
VCID: 2773320AEF6B
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 C HW: 1T0 035 680 C
Component: RNS-MID H06 2720
Revision: AB001001 Serial number: VWZ6Z7Z6023541
Coding: 04000402040000A000
Shop #: WSC 05314 000 00000
ASAM Dataset: ------------------------- ------
VCID: 2E7DC72EC091
2 Faults Found:
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 173
Reset counter: 101
Mileage: 3400 km
Time Indication: 0
01523 - Microphone for Telephone (R38)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 93
Reset counter: 101
Mileage: 3406 km
Time Indication: 0
Date: 2005.14.01
Time: 14:41:25
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 2E7DC72EC091
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 101
Mileage: 3400 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 93
Reset counter: 101
Mileage: 3406 km
Time Indication: 0
Date: 2005.14.01
Time: 14:41:25
End ---------------------------------------------------------------------
I have the same stubborn VCDS errors. So you're not alone there and car doesn't blow up.
So I'll only probably help address your no NAV in MFD problem.
Take whatever you need from it as we have the same car and my RNS510 works fine with steering wheel and MFD!
NOTE 1: Just be careful with my Steering Wheel Module! It's coded for flappy paddle steering wheel.
NOTE 2: Unfortunately I don't have bluetooth however.
Good luck!
