There are some LED working lights available from NARVA of the reasonable size. That's what l would fit.
I find the reversing lights on my Tiguan (MY2011) inadequate for use in my driveway area when I have to use them. I do not have a reversing camera setup and wondered if anyone had upgraded/changed their lights or had any suggestions to increase the illumination. (No I don't want to fit an LED bar ) this is a serious issue for us I would like to find a solution to as rear vision is not the best in this car. I had thought of higher watt globes but am concerned about cooking wires, perhaps LED globes might provide a solution but I am not sure what might be available.
Just read on a long thread from Team V that you have to remove the bumper bar to replace globes!!!! on the Tig. Is this true?
Hi I had the same problem with my Audi A4, was warned against changing voltage in the rear lights so used to put the rear fog on as some extra light. Only had my Tig a week so cant comment on how good or bad it is. I have sensors but I have a real angled driveway so they scream the whole way anyhow. Good luck and I will see if anyone has a master plan
Yes, you have to drop the lower rear bumper to access the special long-life globes. think it mentions it in the manual.
I've always thought about wiring in a $5 50W downlight as an additional reversing light, the ones with the clear cover. Silicon it under the bumper, maybe a solid state relay off the power
TDI tiguan in the drive. ParkAssist, comfort, fogs
Service every 15,000, new fault code every 7,500km
I just fitted LEDs to number plate light too, and yes they are very bright compared to the standard bulbs. I expect they will give more light when reversing, just hope they don't blind the reversing camera. They look great though and no error messages. Also fitted the front parkers, look great as well - pitty they aren't in a better position though - would like to change them over for the indicator position, but that would be too much hassel to change wiring.
Clip, got pictures of those 2 light upgrades. I have a pretty solid tint to match the paint and could do with a little extra light when reversing. Cheers
2010 Tiguan 147, Black, "Savannah" 19x9 Anthracite Wheels, Leather, Sunroof, Tint
This is the difference with mine.
Will try to get a shot of how it illuminates the ground.
