Results 1 to 3 of 3
Thread: Retrofitting OEM fog lights
    Mackay QLD
    Has anybody recently managed to do this to their Tiguans? Found this German online shop selling a "complete" kit for approx €210 inclusive of postage to Australia
    Original VW Tiguan Nebelscheinwerfer NSW KOMPLETT-SET
    The kit includes cabling but it appears to be no more than a meter long so I am wondering where it joins into the main wiring loom. Very keen to attempt this now as I already have a new "AUTO" light switch which incorporates the additional fog light switch and Micro CAN cable to code the new hardware.
    Adelaide hills, SA
    Is it still for your MY08 103TDI ?
    Do you have the wiring diagram for yourTiguan?
    The cable plugs most likely in the fuse box around the battery. The modue it plugs into, is probably missing there.
    Mackay QLD
    Yes I have the wiring diag for (Elsa Win) ws for the RH side that goes into the B554 & ws/ge for the LH side that goes into the C69 connector on the main wiring harness. There appears to be no additional foglight module in the circuit diagram per say. All the wires end up in the J519 main module. I have the diagrams in PDF format. PM your email address and I will forward them to you if you want.
