Results 11 to 20 of 29
Thread: Retro fitting Driver Alert System (DAS)
    Mackay QLD
    What value do you have in your channel 4 adaption settings?
    Is it
    068 000 0000000000
    or
    068 JCB 1111111111
    If it is the latter, then the software version in the CANbus does not support DAS hence the error code you wrote about.
    My original CANbus displayed the same values you have for channels 6,7 and 8.
    MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
    Mods: VCDS tweaks |
    Sep 2014
    Zagreb Croatia
    From what I saw, Channel 4 adaptation is attached to the battery, 068 means that the battery of 68Ah, the next three digits indicate the manufacturer, and at the end serial number of the battery ...
    Retro fitting Driver Alert System (DAS)-batt-png
    mine is 077 VA0 0000000000
    I will change to 068 000 0000000000 and see...
    Thank's!
    Sep 2014
    Zagreb Croatia
    Maybe I have wrong Gateway version, i look in ETKA, there are two version of some gateway part number, Z00 and Z01, this last support DAS, Z00 is without DAS. I bay new from aliex Z01 and i will see....
    Retro fitting Driver Alert System (DAS)-dasa-jpg
    E0A 1D2 5SL 5RQ 1KP 6FB 1AT 3FE 1N3 1NL H7D 4UF 4R4 3CX 3KD 3QT 4X1 4A3 8L5 J0N 7AA 8GU 8T2 9AK 8RM C3S N1A D93 K8D 1ML 4KF 3S7 4GF 4L6 6PE 7K9 6XL 7T6 8QL 8Q6 8X1 4K3 B44 G07 QN2 3L6 9P1 7X2 7X6 7X9 7E6 9ZU 8WC 8WV 7AL 3GN QG1 7MG L58 F0A 3S7 UG4 2UC
    Mackay QLD
    Thanks fo that Prako. I have updated my opening post with your findings from ETKA.
    Unfortunately VCDS is not able to extract that model information when you do an autoscan and the only thing that i could find different from my scanning of my old non DAS CANbus to my new one with it was the channel 4 adaption settings which you cannot change from accessing the #19 CANbus module location but can now be done by accessing the virtual module #61 adaption settings instead. Maybe the default battery settings for the DAS enabled modules in VW'S is 068 000 000000000 and 077 VAO 000000000 in Skoda's?
    I will try and recode mine to reflect my battery details to see if it makes any difference and secondly I wonder if module 61, which is a virtual module can be activated without errors in those vehicles that do not have stop start as standard and again does it make any difference to their operational efficiency?
    Mods: VCDS tweaks |
    Sep 2014
    Zagreb Croatia
    No, I think that is deafault setings for all new gateway 068 000 0000000000. 61 is not virtal module, it is added into gateway module (two modules on same pcb, or three If there are 4C central electic II), and he has connected directly via pin 12 on gateway module to battery module (1K0 915 181 X) on battery negative connection wire controler (LIN bus connection) If there is not battery module, error will be on 61 module (battery modul connectin fault)... BTW i can change in adaptation in 19 gateway module Chanel 04, also in 61 chanel, only in 61 chanel had pop up menu for explain adaptation setings...
    Sorry for my english, i hope that you understand what i wrote...
    Sep 2014
    Zagreb Croatia
    Thumbs up
    Finally works...
    Only diferences is F2 on version with DAS, there is photo...
    Retro fitting Driver Alert System (DAS)-img_5309-jpg
    and on MFD many new options...
    Retro fitting Driver Alert System (DAS)-img_5313-jpg
    Retro fitting Driver Alert System (DAS)-img_5312-jpg
    And on the measuring blocks on #19Gateway, Chanel 6 Futage detection fault code is 0.0, with units without DAS is 4.0 like on my previous post..
    Retro fitting Driver Alert System (DAS)-an2-png
    Thats all, thank's to Bambazonke
    Oct 2014
    Rio de Janeiro
    Prako, good morning!!
    I have the same problem in my Jetta MK6.
    My doubt is: your system works with 3001 version of adress #44?
    If yes, please send me the link to buy that Can Gateway... pleeeease... kkk
    And congratulations to you and Bambazonke!!
    Thanks,
    Felipe
    Sep 2014
    Zagreb Croatia
    Hi! That's is not problem, DAS works with any of III generation stearing 2008>
    You have link on top, Bambazonke post link from AliEx...
    Mackay QLD
    Jul 2011
    Firstly great write up and credit for effort. Just so I can gather all this inside my head everybody out there will pay $$$ for a feature that warns you to take a coffee break after driving so long or after 2hours? Please save your money and start using your brains!!!
