Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 58
Thread: removing front interior light covers
  1. #21
    Jun 2009
    DAMN YOU JOHN!
    I eagerly raced home today in the hope of finding my bulbs but they haven't arrived yet.
    This week for sure so hopefully i will have a slew of pre/post install photos.
  2. #22
    Nov 2008
    QLD
    Quote Originally Posted by team_v View Post
    DAMN YOU JOHN!
    . Just in case you have same problem team_v, I had to build up the tiny wire coming out of the wedge bulbs because they would not make contact in the plastic holders of the roof map lights. Even bending them out didn't work, but a drop of solder got it sorted. The footwell ones were fine though.
  3. #23
    Jun 2009
    Hopefully they go in without a problem when i get them.
    Can't wait tp try them out!!!!!!!!!!!!!!!!!!!!!!!
    Thanks for the heads up though.
  4. #24
    Jul 2010
    Quote Originally Posted by aussietig View Post
    Fellas, this is the online store and brand (Blesk) I'd recommend to you.
    Error free T10 bulbs (in pure white 5000K)
    Application: park lights.
    Note: Pricing is for a pair.
    Having just upgraded my park lights to 6000K, I have a pair of the above Blesk Pure White 5000K for sale.
    $15 (Sydney pickup only) or $20 posted within Australia.
    PM, if you're interested.
    MY11 Tiguan 147TSI (SOLD)
  5. #25
    Nov 2008
    QLD
    I know it refers to colour temp aussie, but what looks different between the 5000 / 6000K?
  6. #26
    Jul 2010
    Quote Originally Posted by clip View Post
    4300K (stock bulbs) have a yellow tinge to them.
    5000K are the closest thing to "pure white".
    6000K are like 5000K in terms of whiteness, but with slight blue tinge to it.
    Anyhow, these bulbs are sold now.
  7. #27
    Nov 2008
    QLD
    thanks aussie, the interior ones I put in must then be 6000 because they have a distinctly blue tinge to them - matches the blue footwell ones very nicely, which in turn matches the blue dash and climate temp guages
  8. #28
    Jul 2010
    Yes based on experience to date, most LEDs you get for interior application (i.e. no in-built resistor) are 6000K.
    Also the higher the Kelvins, the lower the actual output (not to be confused with brightness).
    Quite frankly, I would recommend 5000K as the best balance between colour & output.
    Unfortunately only came to this conclusion after purchasing 6000K HID (D1S) and had to subsequently colour match all the other exterior LED bulbs to that.
  9. #29
    Nov 2008
    QLD
    .... and had to subsequently colour match all the other exterior LED bulbs to that.
    aussie, did you replace your rear number plate light? If so, did the Blesk work?
    I was leaving the bottle shop tonight (hoping to find some $28 cartons!) and looked at the reflection of lights in the window of the shop as I pulled in, the yellow front parkers looked really bad so going to replace them, and the rear number plate if it works.
  10. #30
    Jul 2010
    Yes ... Like I said, have replaced all my bulbs inside & out for LEDs except brakes, reverse & fogs.
    Unfortunately, they work but still can throw up errors.
    Don't know why, but never had this problem with Blesks on my Mk5 Golf GTI.
    Somehow you can't trick the Tig! And I've tried every brand.
    In fact, I have a spare set of park LEDs. PM if you want them at cost.
