I think your issue lies solely with the coding of module 10 only. You do not need to activate anything in the CANbus module 19 that is only if you are fitting the advanced RVC which has a separate box mounted in the rear of the vehicle.
Suggest you do a full Autoscan and send it Support at Ross Tech theymay be able to help providing you are a registered cable owner with them otherwise have a word with Aussietig as he appears to be the only other 147 owner that has a basic RVC retrofitted and also has a module 10 fitted
MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
Mods: VCDS tweaks |
