Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 62
Thread: Rear view camera for tiguan - install completed
  1. #51
    Mackay QLD
    Ok try disabling the towing module 69 in the CANbus #19 module by going into the installation list and unticking it and save it and then try and activate the RVC option in module 10. If it works then go back to the dealer and tell them to check the wiring or possibly recode it so there are no conflicts with your module 10
    BTW have you had a look at the long coding in the towing module? There may be some coding needed there as well may save you a trip to the dealer
    MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
    Mods: VCDS tweaks |
  2. #52
    Nov 2010
    Canberra
    Bambazonke - thanks for the follow up so will try as you suggest. BTW had major towbar wiring issues (warning lights on dash coming on when plugging in the harness) when I picked up the vehicle from the dealer when new and it took several goes for them to fix it so will be interesting none the less
    Quote Originally Posted by Bambazonke View Post
  3. #53
    Nov 2010
    Canberra
    Hi all - finally had some time over the weekend to go over my install...question - the power wire from the back of the RNS510 (that is the plug that connects to the RVC) what position should that connect to on the fuse panel...I had no 16 so is this correct? Also, in my wisdom I thought I would turn off bit 4 'Optical Illustration Active' [park/steer] and it accepted the change but now when I go to turn it back on the 'Coding rejected Error 31: request out of range' so I now have nothing when reverse gear is selected
    I also tried disabling as per Bambazonke's tips below but that made no difference so going down to the dealer tomorrow and see if they can code it as I have now run out of options - I still reckon they did something when they coded the towbar just to get rid of me - hopefully I am wrong
  4. #54
    Nov 2010
    Canberra
    OK - car went to the dealer today and guess what - they couldn't work it out either (no surprises there hey), although they did say that there was a wiring fault between the RNS and the camera but I can assure that is not the case, fault code below:
    02873 - Control Module for Back-Up Camera (J772)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 231
    Mileage: 48888 km
    Time Indication: 0
    Going to disconnect the battery and see if that changes anything and then I will move to the OPS module and try disconnecting that as well. Now I have only audible rear sensors as I cannot enable Bit 4 'Optical Illustration Active' so looks like I will be getting to know my Tiggy pretty well
    BIG thanks to Bambazonke for all his help as I now know where to start looking
    Quote Originally Posted by dmn View Post
  5. #55
    Adelaide hills, SA
    Is your RVC with the moving lines or without?
    Can you email me your full VCDS scan?
  6. #56
    Nov 2010
    Canberra
    Hi Transporter - its the RVC WITHOUT the lines + have emailed you the VCDS scan results - many thanks
  7. #57
    Adelaide hills, SA
    You need to disable the
    02873 - Control Module for Back-Up Camera (J772) in 19 CAN Gateway.
  8. #58
    Nov 2010
    Canberra
    Thanks for the response...I am currently interstate atm (with tiggy) and will check it out when I get back
  9. #59
    Nov 2010
    Canberra
    Hi Transporter - that wasn't enabled but I did go into 10 Park/Steer and de-selected Bit 5 - Rear View Camera installed (directly below Optical Illustration Active) and it now bring this up:
    13636352 - Control Module Not Coded
    U1013 00 [009] - -
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 206
    Mileage: 50789 km
    Date: 2031.14.17
    Time: 19:07:43
    I also disconnected the battery to see if that did anything but I was out of luck...still comes up with the same problem when I try to activate Bit 4 - Optical Illustration Active i.e. 'Coding rejected Error 31: request out of range' so I am running out of luck. Will be checking the towbar wiring just to make sure as I am at a loss now and should have just left Bit 4 'Optical Illustration Active' alone (in 10 - Park/Steer)
    Will send you a copy of my scan so thanks for all your help
  10. #60
    Nov 2010
    Canberra
    **UPDATE**
    OK, an interesting one with much appreciated support from Bambazonke...I disconnected the OPS wires near the fuel tank flap and of course the RNS510 complained that the OPS was disconnected so I accepted it. I then rebooted the RNS510 selected reverse and what do know the camera works as it should but with no OPS. Next step is to check out the wiring that the dealer carried out when fitting the towbar and my guess is that they have either fried the OPS unit when they (the dealer) stuffed up the wiring OR the wiring has been incorrectly terminated by the dealer - the bets are on!
    U1013 00 [009] - -
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 206
    Mileage: 50789 km
    Date: 2031.14.17
    Time: 19:07:43
