Results 1 to 5 of 5
Thread: RCD510 bought - Need help fiiting it in my Tiguan
    Jun 2011
    Perth
    Hi,
    Does anyone have any experience of fitting the RCD510 head unit in a Tiguan? Anyone got any Hints/Tips/fitting instructions?
    Any help would be greatly appreciated..
    Lee
    Jul 2011
    Pretty straight forward, You should use a plastic tool to remove the card holder and the cover on the radio surround the card holder can be difficult to remove so be careful screws are located behind, As for connection it's all plug and play no wiring needed just radio code.
    The only thing may be is that you may need to code the radio unit depending on what functions your vehicle has
    (reverse sensors or camera etc) Good head unit top sound system.
    Adelaide hills, SA
    Quote Originally Posted by Leec33 View Post
    Hi,
    Lee
    Have a look in this post http://www.vwwatercooled.org.au/foru...tml#post476289
    Jun 2011
    Perth
    Thanks guys.. I'll give it a shot this weekend.. Fingers crossed..
    Transporter... I'll check the links for care and info sheet etc in future.
    May 2011
    Ipswich, QLD
    There's also a video on you tube if you search tiguan radio. Really easy to follow as well. I used an old store card to pry off the radio surround with no issues.
