Hi,
Got myself a 2014 Tiguan 132TSI recently and have replaced the RCD310 that came with it to the RCD330 so I can have CarPlay and navigation.
I’m in the midst of installing an aftermarket reverse camera to the car and have a few questions.
The RCD is already programmed for RVC and currently it will give a warning that it cannot detect the RVC but if I pressed ok, the OPS still works. If I install the RVC, does anyone know if the OPS and park assist will still work?
Secondly, I need to connect the blue cable that came with the RVC to the reverse light blue wire. Unfortunately I don’t know which blue wire to tap to. I have done a search and found this link but the picture that show the blue wire and where it’s located can’t be seen.
Rear view camera for tiguan - install completed
I would appreciate advice from anyone that have done the installation or photos as a guide so I can complete the installation.
Thanks.
