I am sure MRXV70 special plug is for speaker level inputs. RCA connectors of the AMP needs a line level signal (pre amp). So I enabled line level(pre amp) signals from RCD510 using a VAGCOM cable.
Funny thing is even though MRX amp's manual mention signal sensing power on work only with speaker level inputs, It will still power up with pre amp outs from RCD 510 feed through RCA connectors. This will save you from trouble of wiring separate remote wake up line for the Amp.
