Page 51 of 55 FirstFirst ... 414950515253 ... LastLast
Results 501 to 510 of 547
Thread: Ramee's Tiguan Build Thread 155KW DSG
  1. #501
    Jun 2013
    Here's what you could end up with if you dropped an 5 cylinder RS3 engine into your Tig: Five cylinders, 2.5 litres, one turbo, 21psi boost, 386kW, 600Nm.
    Yeah! amazing if RS3 going to be like that it is great !
    I would rather buy an old R32 and twin turbo charge it then remove the prop shaft and put an electric motor from a Prius coupled to the haldex with and a battery pack in the back for "Torque Fill" and traction... enough playing with this SUVs and sh!!t. Time to play with big boys!! hahaha!
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
  2. #502
    Jun 2013
    Got two new parcels today. One is a boost sensor and another have three deadcats!! (sorry! three windscreens for my gopro mic)
    So early morning I jump to the work and took the old sensor out and replaced with the new universal boost sensor.
    Oh unfortunately with the new sensor gauge read boost little bit higher about 4 PSI in normal atmospheric conditions.
    But nothing to worry about it, simple 10k trimpot is all that takes to bring it down to correct level. These boost gauges are nothing but little voltmeters so we can reduce voltages send from the boost transducer to show correct calibrated value in the gauge using a variable resister as a voltage divider.
    Voila! gauge reads boost correctly! 0 PSI engine off, -21 idling and 27 -28 PSI peak boost at full throttle in 4th gear as APR claims.
    As usual I dissemble the broken boost sensor to see inside .. Nothing special two op-amps and a pressure sensor and a small regulator in tiny PCB board.
  3. #503
    Jun 2013
    3D printing a car tablet mount
    One of my mates got a hobby 3D printer to play around with his 3D modeling skills. So I asked him to print a dash mount (trim piece) for my car tablet install. And I recorded it in to a time laps video for fun. Piece came out nicely but have to do some finishing and painting before final install.
    Here is the video clip
  4. #504
    Jun 2013
    Some progress shots of the 3D printed tablet mount (trim)
    Just sanded little bit to get the piece to this level.
    Back of the mount. Tablet will go inside and lock in there by few clips.
    Wanted some mat color so plasti dipped it.
    Test mounting in the car. Fit like a glove
    This time I left a slot for the tablet front camera too. In car video calling anyone
  5. #505
    Quote Originally Posted by Ramee View Post
    Nice work Ramee!!!
    Jun 2013
    Nice work Ramee!!!
    Thanks tigger! one day I hope this tech will develop to a level such that we can design and build custom body kits as we desire.
  7. #507
    You'll need a big printer for that!
    Jun 2013
    Yeah! I know at least we could hire something from a Uni
  9. #509
    Oct 2014
    Perth
    that looks factory... look forward to seeing it completed... nice work
  10. #510
    Jun 2013
    Quote Originally Posted by Adam86 View Post
    Thanks mate! Will post final pics soon.
    by the way did you find that KW coilovers ? There are some in Ebay , bit expensive though!
    KW V1 Variant 1 Damper Coilover Suspension VW Tiguan 09 12 Germany Made TUV | eBay
