Page 25 of 55 FirstFirst ... 15232425262735 ... LastLast
Results 241 to 250 of 547
Thread: Ramee's Tiguan Build Thread 155KW DSG
  1. #241
    Jun 2013
    Quote Originally Posted by MGV View Post
    Looks like it rounds to the nearest 0.1 anyway, so you could well have done 4.952! Nice time!
    Thanks man! I hope so!
    Actually I can recode data in a memory card in PBox and see how it rounds up the time. It gives all the acceleration points with a table and interpolated graph, so can get time to two decimal points.
    I will do my next run after install a new intake, and springs and hopefully with a new tune in Easter holidays. By that time I hope to have a run with 104 oct file as well.
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
  2. #242
    Feb 2013
    Perth, WA
    On Stage 1 w/Carbonio my 0-100 (106 indicated on AutoPolar) best was 5.39 sec on a 18 degree night. My best 1/4 Mile was 14.054 3/4 tank of fuel, didn't change tyre pressure or take the sub/suitcase/cameras out of the car (2013 Volkswagen Tiguan 155 TSI 1/4 mile trap speeds 0-60 - DragTimes.com). So I don't think you'll have much of a problem doing sub 5 seconds and low 13 sec 1/4 Miles. The only difference between our cars as far as weight is concerned is that you have a glass roof which might add some weight, but it should only be a small difference.
    The changes I've made since then is a DV Upgrade (existing one crapped itself) and a 2.5" TT Catback exhaust which I doubt would make much of a difference unless I go K04.
    This is what Cliff got who has another K04 Tig in Australia.
    2013 Volkswagen Tiguan 132 pacific 1/4 mile Drag Racing timeslip specs 0-60 - DragTimes.com
    *Cliff doesn't have a DP yet so he's probably got a decent improvement on that.
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
  3. #243
    Jun 2013
    Quote Originally Posted by Wynnston View Post
    Yes as a next phase of mods I will try to reduce the weight of the car more than 50 kg to bring it's curb weight to 15xx kg bracket instead of 16xx kg. I will do this with a light weight exhaust, brakes, aluminium lower control arms and light weight crank pulley, wheels ,spare tire removal and a light weight battery.
    Then for the performance upgrade I will add intake, cat back, DV2+ and new tune so I will be able to add another 20 - 25 hp and about 40 lb ft extra torque on top what I have now.
    If everything fails I may run water meth with 104 oct file to call it a day and hopefully conclude my build thread end of this year
  4. #244
    Feb 2013
    Perth, WA
    You will never stop haha
  5. #245
    Jun 2013
    I will, I promise! Carbonio and GFB DV+ on the way. I will build my own version of catback.
    Then all performance mods will be over except new upcoming tune.
    PS: You could be right too. I am just contemplating of reboring and upgrading pistons and rods too. hahaha!
  6. #246
    Quote Originally Posted by Ramee View Post
    Yeah, yeah I've heard that one before....
    Jun 2013
    Could it be a Deja vu ?!
  8. #248
    Jun 2013
    Today two new parcels arrived One is a long forgotten spare spark plug set. Second one is just the thing I wanted. some go fast bits
    I will install this kit during the weekend with a second hand Carbonio intake I purchased from Tiggy1. Hopefully they do what their name suggests
  9. #249
    That Carbio has done the rounds... Started out on Sharkies Tig then almost got on my car, ended up with Tiggy1 instead and now it's going on your car
    You've got a piece of forum history in your hands....
    Re go fast bits unfortunately there's no evidence that your car will go faster with it
    Jun 2013
    oh! I should have this RACV/RACQ? tested! ... Lol, May be it is destined to be in a K04 Tig !
    I heard some good news about this DV, if it can stop any boost leaks under high boost may be it will !!
