Page 22 of 55 FirstFirst ... 12202122232432 ... LastLast
Results 211 to 220 of 547
Thread: Ramee's Tiguan Build Thread 155KW DSG
  1. #211
    Feb 2013
    Perth, WA
    Ugh. I can't keep up Ramee, now I want a K04
    Hope it goes well!
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
  2. #212
    Aug 2013
    mudgee, nsw
    Go bigger GT2871
    2010 POLO 77TSI COMFORTLINE, CANDY WHITE, H&R 30/50 sport cup kit, 18x8 lenso speed 3
    2016 SKODA RS230 WAGON, MOON WHITE, TECH,TAILGATE, P/ROOF, HP UPGRADED CLUTCH, JB4, DTE PEDAL BOX, EIBACH SPORTLINES, AVID1 18X8.5 AV20'S, CTS TMD/TIP, 034 DOGBONE INSERT, OBD11 MODS
  3. #213
    Jun 2013
    Quote Originally Posted by BLKMKV View Post
    Go bigger GT2871
    I have a better plan for spending 10K Get Audi TTRS engine (5 cylinder) from US and swap the engine. Then need to get APR map with a new ECU. Haha Or just wait till RSQ3 comes out !
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
  4. #214
    Jun 2013
    Quote Originally Posted by Wynnston View Post
    Hope it goes well!
    Thanks buddy! I am sure you will get there soon ...
  5. #215
    Erskineville, NSW
    Quote Originally Posted by Ramee View Post
    Yes, my tuner recommend Motul. Bit expensive and need frequent oil change too. I will probably give it a try later. Thanks
    Given the tune of the vehicle & the way I perceive you might drive, I'd recommend 5000km intervals on that oil
  6. #216
    Ramee how did the K04 upgrade go? Or is this upgrade going to take a bit more than one weekend?
    Jun 2013
    I managed to complete it in time. Lucky I had 3 days to complete it, It took me two and half days to do every thing I think someone can do it with in two days but I had to go to Bunnigs and few other shops to get some tools and distilled water.. I took some pictures of the install and I am going to upload them now.
  8. #218
    Ramee where did you go? Have you gone out for another "test" drive???
    Jun 2013
    Tiguan K04 Turbo Install
    So finally I did the turbo swap successfully with out any big issues during the process. I managed to it in two and half days while taking my time and working alone. Few of my friends wanted to help me but I rather did it myself because it let me to concentrate on work and more freedom with my time Anyway now everything is installed properly and no oil/coolant leaks and car running fine without any misfiring issues. Also now that annoying waste gate rattling noise is gone and engine turbo making loud roar and sweet whistle with a never ending pull till red line makes me feel my hard work has already paid off! I would say K04 Tiguan install is a epic success !.
    I took lot of pictures during the K04 turbo install and some of the important ones I will upload here..
    Getting ready for the job, Intake is removed and also coilpack harness and coolant return line moved to front to get some clearance.
    First step is to remove the heat shield which obstruct the access to the turbo
    Heat shield is out
    Next oxygen sensor is removed.
    Time to separate the down pipe from turbo. Removing downpipe flange nuts one by one.
    Then unbolted the downpipe supporting bracket
    Downpipe was separated and moved to a side
    Next time to remove compressor output piping. Basically need to remove the pancake pipe.
    Pancake pipe is removed
    Now turbo is free from three sides and need to separate from oil and coolant lines and DV electrical connections
    Finally need to remove these top five nuts and we can take the turbo out
    Hurrah!! one is down , four more to go
    At last poor bugger is out It did serve me well
  10. #220
    Jun 2013
    Next day morning new K04 turbo is being prepared for the install. It is getting few parts from old mate.
    Time to say final good bye New one is ready to go in!
    This is where K04 going to end up with
    And it is mounted
    Next installed the oil and coolant supply and returned lines
    Finally every thing is done and dusted and finished product
