Page 20 of 55 FirstFirst ... 10181920212230 ... LastLast
Results 191 to 200 of 547
Thread: Ramee's Tiguan Build Thread 155KW DSG
  1. #191
    Erskineville, NSW
    The bar has a warranty. take it back for replacement as it shouldn't do that
  2. #192
    Jun 2013
    I think I finally figured out the culprit. End link bolts need to tighten down like crazy to avoid that noise, First I thought I did over tight them but later found a DIY for coilovers which gives torque specs for end link bolts of 60Nm Any way I tight them as far as I can (did not have a torque wrench with 60Nm range) and noise seems to go way for now. But I think better tight them again with a proper torque wrench.
  3. #193
    Aug 2013
    mudgee, nsw
    Quote Originally Posted by Ramee View Post
    I had that exact same issue a few months back with my golf, took me ages to find it
    2010 POLO 77TSI COMFORTLINE, CANDY WHITE, H&R 30/50 sport cup kit, 18x8 lenso speed 3
    2016 SKODA RS230 WAGON, MOON WHITE, TECH,TAILGATE, P/ROOF, HP UPGRADED CLUTCH, JB4, DTE PEDAL BOX, EIBACH SPORTLINES, AVID1 18X8.5 AV20'S, CTS TMD/TIP, 034 DOGBONE INSERT, OBD11 MODS
  4. #194
    Jun 2013
    Later I tried to re tight the sway bar end link bolts and the result of applying 60 Nm torque is..
    So as a temporary solution this was used. Two 10mm bolts from bunnings cut to proper length with SS washers. 60Nm? I will give them 100Nm .. lol
    Definitely these sway bars need adjustable end links for stop pre loading. ( at least my one) Also put them back again in medium stiff setting because handling is bit unpredictable with high stiff setting. These will stay there until I get front sway bar installed.
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
  5. #195
    Jun 2013
    Also got Eibach Pro lowering springs. Look good but they wouldn't go in until I get Koni's
  6. #196
    Jun 2013
    New short UHF antenna installed. This one is more civilised for urban driving
  7. #197
    Jun 2013
    Today I picked up few stuff waited for me in the post office and a big box from APR VIC master dealer. Apart from big box other items are R8 coil packs, PFR7B double platinum spark plugs, engine oil, oil filter, G13 coolant, digital torque adaptor and few tools Dean from FASTSTUFF lend me for free .
    Any guesses what is in the big box?
  8. #198
    Jun 2013
    It is this.. I waited almost 5 weeks to get it from APR and finally here
  9. #199
    Jun 2013
    Let me open the box please
    This is what came with the APR K04 kit
    Wastegate and exhaust turbine
    How heavy is a K04 turbo ?
  10. #200
    Oct 2010
    Can't wait to see the DIY install. Looks like you need a couple bottles of whisky on standby.
