2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
When you go full stiff, keep in mind who might be driving the car as some vehicles can get a bit tail-happy, especially in the wet.
It's not a bad idea if you go full-stiff to get out on a wet day and go around a full sweeper or a cloverleaf with ESP off & doing about 7/10ths & accelerating & back off the throttle suddenly to see if you get snap-oversteer.
On my Liberty on full-stiff it was fairly easy to invoke oversteer when I had it on full-stiff. You didn't get caught out if you were concentrating but it would catch you if your mind was elsewhere or if somebody was driving that wasn't aware of the handling charateristics. The mid-setting was totally forgiving & the ride was nicer as well as the firmer the setting, the more "coupled" you are making the independant suspension - which kind-of defeats the purpose of IRS.
Yes I will keep the sway bar in current setting ( mid stiffness ) as I am quite happy with it. Still when I go over road humps ( speed breakers) if only one rear wheel goes over the bump I clearly feel the hardness of the sway bar compared to stock one. Stock sway bar is fairly forgiving and allow for more wheel articulation to absorb the impact, while with WLSB one it feels bit rough and a vibration.
I hates speed humps... Some are so unbelievably harsh it isn't funny...
I've found some of these "traffic calming devices" can turn a boring side streets into a slalom courseI'm sure it's not how the original designers intended but it can be a bit of fun.
Also regarding some speed hump designs you can (if you get it right) take them at reasonable speed if you get the weight transfer happening in your car right and can actually be smoother than slowing right down.... I mean what is your suspension for right???
Quick updateMy WL sway bar started to make a annoying grinding noise after installation. After some inspection I could not figure out what was wrong except when I remove the end link connections sound stopped. It was also clear WL sway bar is not 100% perfect in assembly as one mounting bracket need to mount little bit higher to stop pre loading the bar.
I remounted the sway bar again with stiffest setting this time with end link connected first and then bolting down two mounting brackets. They placed little bit offset to each other (not parallel) but now grinding noise seems to be gone.
