Page 18 of 55 FirstFirst ... 8161718192028 ... LastLast
Results 171 to 180 of 547
Thread: Ramee's Tiguan Build Thread 155KW DSG
  1. #171
    Quote Originally Posted by Ramee View Post
    HPA K04 kit is really nice and specially they are going to make that tune suitable with their new TSI intake manifold which is really nice. If they get it right may be time to change the tune
    On positive side for APR they are almost finishing a version 3 tune for K04 which promises more power ~380hp and torque.
    Yes if there was someone able to do the HPA tunes here I'd be tempted to go K04/intake manifold +flapper delete.
    Jun 2013
    Tiguan S3 Intercooler Install
    Today I was able to install S3 intercooler for Tig. I did it solo with in about 6 hours time and without too much struggling. Tig has bit more ground clearance than GTI s so I did not have to jack it up during the swap. I got two hoses with the S3 intercooler but one of them (pre intercooler/ turbo side) one is too short for Tig. So I used stock hose but had to cut about half an inch to clear the swelled area of the hose and to get the perfect length. For the other side of the intercooler, I could use the S3 hose easily. I used APR and other internet resources as a reference and even though they are for GTIs, still closely relevant for Tigs.
    Some pictures of the install.
    Front bumper removed.
    Water is leaking because I forgot clamp the headlight washer line!
    Bumper bar, headlights, and intercooler supporting bracket removed.
    No need to remove the hood unlocking wire in Tigs. Just leave the supporting bracket away with wire attached.
    Intercooler is in between two radiators (AC and Engine coolant). Just unbolted both of them from the intercooler.
    S3 vs stock intercooler. Not much difference in size S3 may be 4mm thicker than stock and has aluminium end tanks.
    S3 is about to go in. Stock one is going to garbage
    S3 intercooler in the car!
    Did a test drive, car feels bit livelier. But today is not a very hot day so benefits will be more clear in a 30+ degree day
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
  3. #173
    Nice job. Are both the stock hoses a little too long? Just in case I don't get hoses with the intercooler...
    So did you get your sway bar fitted too? or has that been pushed out to next weekend?
    I'm guessing this will be a one-way install for me too. Given the time taken to put it in, it doesn't seem worth it to pull it out afterwards. Though I'll probably keep the stock intercooler anyway (and worry abouth te cut hoses later).
    I'm not sure it's going to be noticeable. Maybe just a placebo effect
    Jun 2013
    Yes both stock ones are little too long.. Not much, may be extra half an inch long. Problem with them is stock intercooler inlet and exits are bit larger than S3 intercoioler ends. So these stock pipes go loosely over the S3 ends. Better to cut stock piping ends bit to get more through fit and avoid the swelled area of stock hoses.
    I could not install my sway bay yet because I was very tired after end of this exercise. Good thing is I have something to do again to the car next weekend too
    He he.. May be, but to motivate you I would say it gives extra 10 hp in hot days
  5. #175
    Erskineville, NSW
    RSB will take you 30m tops.
    If you park where a flat is falling away to a slope you don't even have to jack the car up just slide under from the back.
    You'll need some triple-sqauare bits. I can't remeber the size - sorry.
  6. #176
    Jun 2013
    Thanks brad, I will give it a go as soon as I get a chance. Looks like an easy enough job for me
  7. #177
    Jun 2013
    Some data logs of intake air temperatures with stock and S3 intercoolers installed. They logged in nearly similar times of different days with ambient temperatures nearly same on same path from my work to home. Logs show a very clear decrease in intake temps with S3 intercooler even though it is not an ideal intercooler, still heat soak little bit at traffic lights.
  8. #178
    Nice work Ramee. Always good to have the hard facts to support spending the time and $.
    Jun 2013
    Tig's Rear Sway Bar Install
    Today I changed the Tig's rear sway bar with a Whiteline 24mm Heavy duty sway bar. Whiteline sway bar is a solid bar compared to stock hollow one so considerably heavier. Whiteline one comes with two stiffness settings and I first installed it in low stiffness position. During the test drive I could feel considerable improvement in handling even with mild setting and body roll is fairly under control, but you can feel it is still there. There are some favourite spots where I can really see the handling improvement of the Tig such as long curvy downhill road sections and I can safely say there is a significant improvement in body roll.
    Stock vs Whiteline sway bar
    New sway bar installed. I had to use M10 and M6 XZN bits for the operation.
    I did not have XZN bits in my tool box so had to buy some. Supercheap and local Bunnings did not have them, Total Tools have them as a set with other mixture of bits.
  10. #180
    Surprised you didn't go for the stiffest setting first
