You've got the opportunity to go with a really nice concave look or something with a big lip. My personal preference on a Tig is for a concave rim.
The bigger the rim and more aggressive offset the more the dish
Yeah not bad! I like concave looks, reason I went for wheel arches is to get a wider foot print. So wheel offset going to give me that. I can't go too much offset because it may generate more strain on wheel bearings. But i think ET20 or 25 would be ok. Rubber will fill the arches
On another note air suspension is one of my distant dreams too. If I decided to keep the car for a long time I will do that too, not in near future though.
2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
Had a close encounter with a Blue R32 and this is the first time Tig met a R32 side by side. First time it was a surprise for the Tig as R32 immediately started to put about a car distance from Tig but Tig caught up to it quickly and showed the turbo power. After a friendly chat with the R32 guys second run was not that surprising but still R32 pulled hard from the start but Tig easily killed it with in first 10 yards.
R32 guys were really surprised too haha!
Honestly I am surprised about the low end power delivery of the R32. I think even a golf R will struggle first few meters with a R32 from start without launch control!
Ramee, you need a Sprint booster if you're going to be doing the traffic lights GP. Speeds up throttle response so you won't lose quite so much distance off the line
It causes the DSG gearbox to lock up a lot quicker so there's less of the DSG "hesitation". Downsides with running it is that throttle control is more of a challenge for the twisties/round abouts. I switch mine on/off when I need it.
haha! yes looks like I may need one.. one more thing to my mod list
Also I think it is also turbo lag causing problems during start up. He has all 6 cylinders from the beginning but Tig only got 4 and no turbo for start. I think that is the main reason VW introduce launch control for turbo line up.. for traffic light GP
So I wander BIG turbo guys must be having more problems during initial stage. Looks like K04 is an acceptable middle ground option for that sort of business. Yeah LC is bit hard to do in TL GP, but Tig being underdog it always get a second chance and then you can prepare for a LC Because second time mostly other guy do the same !
Do you ever go to the race track or drag strip? Because that's where those shenanigans belong.
Please don't give performance car enthusiasts a bad name by racing on the street. It doesn't do any of us any good.
Update about NewSouth boost gauge. Few weeks after install yesterday it started paying up! It stated to show -20 PSI even engine is not running and when idling it goes to -30 and stay there even in boost. Looks like boost sensor not working properly since when I move the sensor needle moves irrationally. Checked all the wires and voltages and they are ok. So decided to get a universal boost sensor and see how it goes.
Problem is that universal sensor requires 12V power compared 5V power use by the original sensor. I hope universal one has a 5V regulator inside and generate output signal comparable to the original one.
