I wasn't aware that the Carbonio had worse performance in traffic. Probably also due to its position I'd say. A lot of other intakes have an elbow and take air from around the back of the headlight area whereas the Carbonio is "straight through". So it'll probably cop a bit more heat from the engine due to proximity.
I'm actually interested in the GFB DV+ but not sure it's going to provide any major gains unless you've got a faulty/busted DV.
Either way I'll be interested to get feedback and see if you can crack into the 4's
