I got the K04 flash done at the same time. It is still APR K04 2.2 firmware version. But hopefully may get the 3.0 version with APR mobile in the future.
Dean at FASTSTUFF did let me unrestricted access to see how it is done, and it is great to see it is being done in flesh,apart from the part they split open the ECU with nifty little tools.
This is the APR standalone programmer for bench flashing ECUs. When ECU bootloader do not play nicely with port programming they bring this bad boy in to action.
ECU getting reflashed with stock,95,98,104 maps with V2.2 software.
2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
I am sure the weight gain will be more than offset by the additional performance
So how does your car run with the K04 file but running the K03?
I don't drive it harder as advised from APR. Car is in K04 stock map so I don't know how many hp it is putting out (155 kW or 190 kW) but I like how it drives already with new map.( not much difference to stage 2 but little smoother low end )
I think if I floor it, probably engine will go lean because K03 spool quickly than K04 and ECU is not ready for the faster spool. Then at higher RPM engine probably will go richer as K03 can not provide enough requested boost levels. But in simulated stock mapping I don't think this will happen because most probably APR cut the boost beyond a certain level.
Good luck this weekend. Remember to take a few photos along the way.... Always forget until I'm halfway through.
Oil looks like Castrol Edge Sport. It's 502.00 isn't it? It's a good oil but a bit low rent compared to your other bits & bobs.
