Today I changed the Tig's rear sway bar with a Whiteline 24mm Heavy duty sway bar. Whiteline sway bar is a solid bar compared to stock hollow one so considerably heavier. Whiteline one comes with two stiffness settings and I first installed it in low stiffness position. During the test drive I could feel considerable improvement in handling even with mild setting and body roll is fairly under control, but you can feel it is still there. There are some favourite spots where I can really see the handling improvement of the Tig such as long curvy downhill road sections and I can safely say there is a significant improvement in body roll.
Some pictures of the install.
Stock vs Whiteline sway bar
New sway bar installed. I had to use M10 and M6 XZN bits for the operation.
I did not have XZN bits in my tool box so had to buy some. Supercheap and local Bunnings did not have them, Total Tools have them as a set with other mixture of bits.
2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
When you go full stiff, keep in mind who might be driving the car as some vehicles can get a bit tail-happy, especially in the wet.
It's not a bad idea if you go full-stiff to get out on a wet day and go around a full sweeper or a cloverleaf with ESP off & doing about 7/10ths & accelerating & back off the throttle suddenly to see if you get snap-oversteer.
On my Liberty on full-stiff it was fairly easy to invoke oversteer when I had it on full-stiff. You didn't get caught out if you were concentrating but it would catch you if your mind was elsewhere or if somebody was driving that wasn't aware of the handling charateristics. The mid-setting was totally forgiving & the ride was nicer as well as the firmer the setting, the more "coupled" you are making the independant suspension - which kind-of defeats the purpose of IRS.
Yes I will keep the sway bar in current setting ( mid stiffness ) as I am quite happy with it. Still when I go over road humps ( speed breakers) if only one rear wheel goes over the bump I clearly feel the hardness of the sway bar compared to stock one. Stock sway bar is fairly forgiving and allow for more wheel articulation to absorb the impact, while with WLSB one it feels bit rough and a vibration.
I hates speed humps... Some are so unbelievably harsh it isn't funny...
I've found some of these "traffic calming devices" can turn a boring side streets into a slalom courseI'm sure it's not how the original designers intended but it can be a bit of fun.
Also regarding some speed hump designs you can (if you get it right) take them at reasonable speed if you get the weight transfer happening in your car right and can actually be smoother than slowing right down.... I mean what is your suspension for right???
