Going to be a trial and error job I think, I'm in pretty much the same boat with my rim choices. Just a matter of finding what works and what doesn't the hard way really.![]()
Hi all,
Just got my TDI manual almost 3 weeks ago and looking to upgrade to 18" alloys from the 16". Interested in these (R32 replicas) from Tempe tyres:
http://www.tempetyres.com.au/product...=&part_no=1145
The sales guy said there should be no problem fitting them on, but I read the following on VWvortex:
http://forums.vwvortex.com/zerothread?id=4434335
which suggests that they may not fit but I think they are talking about originals there. My question is do you think from the add that these replicas will fit straight on as I don't always trust salespeople and do you think they will improve the ride over the standard 16" given that they were not designed for the tig. also I have the offroad pack with tyre pressure monitors, hence, by replacing the alloys will that still work. one more thing they come with Kumho tyres, are these better than the Bridgestones that are on my 16" alloys.
thanks guys in advance.![]()
Forever blowing bubbles.
Have to remember that spacers can always "fix" offset problems ....
Best bet would be to find the offset, centre bore and wheel nut fitment and compre it to aftermarket or vw oem range.
Also i would get the guy from tempetyres to send you an email stating that it will fit so if it doesn't you can send them back and clai that you were led on.
Spacers will make it fit if the offset is wrong but i thought they were illegal.
thanks guys, but what do you mean by trial and error?
i don't want to keep on going back there and i certainly would not want to do damage to the car. shouldn't the people at tempe tyres know if the rims will fit straight on without any problems. also what about the tyre pressure monitor does anyone know if they will still work. again the sales person said it should not be a problem, but the thing is i am not keen on experimenting on my tig especially when i am paying thousands to fit new alloys!
i have read all the threads here but still confused as to which after market alloys actually fit without any problems and the need for spacers. please, what are the exact specs of the 18" optional tig rims so that i can quote them to the salesperson and sharkie can you please explain what the spacers are for even if the replica rim is supposedly the correct size (512).
i live 15 minutes away so i actually popped in to see them and they can fit the rims as well, so i wont need to fit them on myself.
Tiguan TDI, 6spd Tiptronic Auto
Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
Avg 7.63L/100km over 189,000kms
I did a quick search and fond the VW specs for the Davenport wheels (OEM 18")
Wheel size: 7J x 18, ET43, LK 5/112
Tyre size: 235/50 R18
So if you do those specs for the R32 wheels you should be okay.
A spacer from memory is used by attaching on the inside of the wheel to push it out further, allowing it to clear the suspension and brake setup.
It is used for putting lower offset wheels on bigger offset cars.
thanks again guys. i will go in there in the next few days with the info. you provided and post an update and i am really hoping to get those R32s on my tig.
Some info on spacers here ....
http://www.hrsprings.com/products/trak/
Speak to GTI_Dave, he'd get it in if you need it ...
