Hi Gang,
Can someone please point me in the wright direction for the procedure on how to correctly set the oil level in my gearbox, I have spent the best part of the day searching the net with no luck.
The specific model is a DQ500,OBT,OBH DSG in a 2010 Tiguan TDI with 4motion,I have changed oil in my Golf 6 speed by following the various you tube/forum how to's and all went well and using the expected amount of oil.
when I drained the oil I collected very close to two litres and then another three after taking out the tube used to set the level like the one in my golf,I was thinking it should be the same as my golf with only a small amount of oil coming out after removing the bung so I saw surprised when two litres came out.
I rang my local VW dealer and was told they normally do a refill of about 5.3 and they also told me it had two seperate oil chambers so now I am confused as the only DSG I could find with two chambers are in much later vehicles so I think they may have given me the wrong info , So in the end I just put back the same amount of 5 litres as I drained.
Any help on this will be greatly appreciated.
Cheers.
