Results 1 to 7 of 7
Thread: Propeller Shaft Damper
    Feb 2013
    Perth, WA
    Hi Everyone.
    Just got my Tig back from a service and they've noted that the prop shaft has some play in it and it appears that the rubber damper for the shaft where it connects to the rear diff is perished.
    Has anyone replaced one of these on a Tig before and know the P/N.
    I get my car serviced by an independent because I'm in the country, they do a great job but I want to double check the part/replacement procedure for myself.
    Ramee, I remembered that you did some work with your haldex system, did you touch this part and did yours have any play in it?
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
    Dec 2008
    Sydney/Canberra
    I've seen one go before. Not sure why. I've never seen the same part fail on other models like the R Line Golfs and Passats.
    Part number should be 1K0521307A. Worth running this by your preferred VW dealer's parts department with your VIN to confirm, in case there's a revised version, or variation.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Feb 2013
    Perth, WA
    Thanks for that.
    It's most likely 1 of 2 things that could have caused it.
    1. A few months ago, a new exhaust was installed by a bunch of idiots and they managed to snag one of the brackets on the rim of it while it was spinning as there was a chunk missing out of the bracket and a gash mark on the exterior of it. I got it checked out at the time I discovered it and everything "seemed" ok and an adjustment was made to the exhaust.
    2. Car is tuned (stage 2 APR) and I've used launch control quite a bit at the drags (not recently) but it could explain premature wear.
    Jun 2013
    Quote Originally Posted by Wynnston View Post
    Sorry to hear about that Wynnston, but luckily it is not very expensive or hard job to fix it. My rubber couplings were ok when I did my work and there was no play in the rubber coupling itself. But there is a definite play in the center (middle) ball joint of the drive shaft to cope with suspension movements. I think you better get it fix soon as possible as this may cause drive shaft misalignment and failure of other parts.
    Meantime you may completely remove the driveshaft and have some GTI style fun like I did. With stage 2 it is quite fun.
    For the cause I think it is stage 2 tune is the one to get the blame. Stage 2 tune can create huge torques under low RPM with tiny k03 turbo and may create severe stress on drivetrain and transmission components so launching with it is not a very good idea. I also recommend an upgraded haldex controller as this make haldex system ready for high torque transmitting through it way before stock controller responds so less impulsive force when haldex kick in.
    I hate those doggy exhaust places they act like experts but do a worst crappy job and don't care anything else under the car and complexity of these machines.
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
    Feb 2013
    Perth, WA
    Quote Originally Posted by Ramee View Post
    Thanks Ramee. I've pulled up a diagram and it shows one attached to the driveshaft and another to the rear diff, is this the case (is there two) or is it just one part which they are illustrating twice?
    Propeller shaft. Fits: Volkswagen (VW) | Jim Ellis VW Parts
    W
    Jun 2013
    W
    It is just a one part. Got Six holes in it, 3 bolts goes to flange in rear diff and other three (opposite direction) go the flange in drive shaft. Number 6 is the part you need
    Also better replace all the bolts too as they are one time used (stretch bolts) and need a torque wrench for proper torque setting.
    Found a pic
    Propeller Shaft Damper-p1020112_zps2065c77d-jpg
    Feb 2013
    Perth, WA
    Found a pic
    Thanks mate, as usual, you're a legend!
