Hi Mick,
I do lots of Highway kms and I seem to pick up self tapping screws. I've just gotten over the last one where I pulled the screw out and plugged it, and it would be fine for a few days then go flat. That saga went on for a while till I got a new tyre, and now that new one has a self tapper in it. I'm leaving it be as it is staying up!
That said I've had to use my space saver spare on a few occasions, once on a trip to and from Toowoomba in horrible rain, and it was fine. Obviously on the Warrego I had to push the space saver well past it's 80kph "sticker" limit, but in my Yeti the tyre is a conti rated to 240kph or something, and with AWD I didnlt notice a thing. I even took it for a bit of a fang out the back of Toowoomba so get a feel for how it may "let go" and slide, and with traction control on, it was almost impossible to get it to misbehave. So I think the typical AWD space saver is pretty good, as opposed to the Golfs where it truly is a bicycle wheel in width!
My bet is you will be pressed for space on a family trip, so in your shoes - and I want to take my kids camping at Carnarvon when it heats up a bit - I'll just take a small air compressor, a can of spray goo ( not the green slime stuff - that is HORRIBLE to drive on ) and my space saver spare.
As for octane, the Tig is designed to handle lower fuel grades for stints, the knock sensor will retard the timing if it detects ping, and so long as it's not a boiling hot day and you are not towing a big load or up it for the rent, you will be fine on basic fuel if need be. If you do have to drive on lower octane fuel, just go easy on the car and you will be fine - also I've yet to see any servo that doesn't have some Wynns on the shelf at twice normal price if you need it!
Driving that far, out west, perhaps look into some paint on or stock on body protection, like the sort of stuff they paint on glass in new houses, I'd consider putting that on the front and peeling it off when done, 3600kms is going to leave you with some good stone chips!
Finally I'd take some windscreen glue / sticker kits in case of a rock hit, I'd rate that as more likely that anything with all those friendly trucks!
