Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Pre-facelift 2.0L TSI Buying Tips
    Jun 2014
    Hi all - I'm looking to get my hands on a manual 2.0L TSI model, around 50,000kms and wondering if there's any real drawbacks with the 2009 models?
    From what I can tell, mechanically it's the same as the other 'pre-facelift' models, but it has a different multi-function display and different steering wheel controls.
    Does this limit any upgrade pathway?
    I'd intend to do a 'stage 1' tune of some type, but not too much more in the way of modifications. Maybe a stereo upgrade.
    Any things to avoid, or watch for?
    Jun 2009
    The 2009 may still have the red MFD, depends when it was brought in.
    Shouldn't be any concern for the upgrade path as the ecu encryption only became a problem for the 2011 models i believe.
    As long as it has had the yearly service schedule completed and the recall for door handles and fuse overheat done it should be good to go.
    The red display and steering wheel is from the Mk5 Golf. In 2010 they went to the white MFD. It does make a difference if you intend upgrading the stereo/Bluetooth as newer RNS/BT units will not be 100% compatible with the older style displays/steering wheel controls.
    On the brighter side the older Tigs didn't tend to have security on the ECUs which makes it much simpler to tune. These can be flashed over the OBD port and doesn't require pulling the ECU out of the car.
    Jun 2014
    Quote Originally Posted by team_v View Post
    to go.
    Yeah, a fair few of them have the red MFD. I must admit, the 'round button' steering wheels look a lot older, but that's being a bit fussy.
    This does concern me a little. I generally upgrade the stereo on all my cars, and have been quite impressed with the VW 'upgradability' from within the VW family. I would like to put one of the SatNav units in the car, so maybe avoiding a 'red MFD' model might be a wise idea.
    Thanks for speedy replies gents. The hunt continues!
    Quote Originally Posted by Andres View Post
    You can put a new RNS510 into an older car but you have to also upgrade other modules to get everything working so the unit shuts down properly and doesn't drain your battery flat.
    Mackay QLD
    CANbus upgrades not required on any Tiguans sold in Australia. I upgraded my RCD300 in my first Tiguan purchased in May 2008 with an RCD510 in 2011 without any battery drainage issue.
    MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
    Mods: VCDS tweaks |
    Mar 2011
    Gold Coast QLD
    Quote Originally Posted by Bambazonke View Post
    Hi I can confirm this - I have a 2008 Tiguan, one of the first ever delivered in Australia. It is great. Don't worry about the red MFD and steering wheel, it really doesn't make a difference. In fact I find the red/blue dash much cooler than the boring new white one
    You can easily put a brand new RNS510 in there, and it will work with the red MFD just fine (you just need to VAGCOM into the radio and tell it to use DDP protocol (red screen) instead of BAP protocol (white screen). Then you can install latest 9W7 bluetooth module under the seat, and use the RNS510 satnav to control it. (The 9W7 menu won't show on the red MFD unless you buy a AutoPolar FIS thing as well for about $200-400)
    Check my links, or carsystems.eu for all the parts you need from Poland, or jku.com.au for an aussie dealer. No affiliation.
    PS: I am also swapping the old round-button Mk5 style wheel to the newer Mk6 style flat bottom R-wheel: Cost $500 for the wheel with airbag and $80 for the new steering wheel control module. eBa FTW.
    - 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
    - 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
    Jun 2014
    Cheers guys - that's very handy to know.
    Going to check these out on the weekend hopefully:
    A tad more than I want to spend, but very low kms - and I like white.
    2011 Volkswagen Tiguan 5N 132TSI MY12 4-Motion
    This one is more kms than I'd like and not a huge fan of silver, but considerably cheaper:
    2009 Volkswagen Tiguan 5N 125TSI MY10 4-Motion
    Mar 2011
    Gold Coast QLD
    The white one is nice! Price is much too high though. Haggle? Interesting to see even the 2009/MY10 already has the white MFD so you should be set for the RNS510 upgrade
    Mackay QLD
    I would take the white one the mileage is very low hardly run in plus it is full house with leather comfort pack fogs which at new would have been an extra 5 to 6k over the basic purchase price so 25k is reasonable considering it is the 132TSi. Maybe offer 23 or 24k cash!
    Mods: VCDS tweaks |
