Yes, I agree a lot. You want your suspension to work, it what keeps the tyres on our crappy roads. If you stiffen it up too much with springs and especially big sway bars, you can reduce this from happening. If you really want it to stick like s*^t to a bear, remove the sway bar- it might roll around and scrape the sills, but it'll stick. Pumping up the rear sway bar too much can also increase tendencay for snap oversteer, particualry if you tend to drive hard out of corners (level/risk depending on chassis stiffness and your ability to drive too ) - just something else to think about.
