Hi folks.
Had the Parking Brake Fault Light come on after changing the rear brake pads (2010 Tiguan)
Did the mechanical wind-out of the electric motors.
Brakes themselves are working fine - its just the Fault Light, and it's impact on the operation of the Park Brake. The Park Brake worked fine before I changed the pads.
Thought it might just need to have the code cleared, but my OBDII/EOBD reader doesn't seem to work with this car (I go it from ALDI - I know, I know...)
Am I on the right track with just needing the code cleared? Or is there something more sinister at play here?
Alistair
Probably needs a vcds on it. The calipers get wound back electrically, "enter lining change mode".
Then just push pistons back.
Then " exit lining change mode"
Might be ok without pulling it alart again
Job done.
